Taking out the pin that holds the shiftlinkage on...help me please!
i put a GSR motor in my del sol and everything is ready to go but i have a big problem... The pin that holds in the shiftlinkage is stuck. Ive tryed every thing to get it out used a punch th same size as the pin and beat on it..nothing used a 10mm bolt and threaded it in a little and hit it with power...nothing so i thought about drillin it out but when i got it going the drill broke off inside the pin... Im so screwed if anyone can help i would thank u much...
Re: Taking out the pin that holds the shiftlinkage on...help me please! (bh2285)
yeah i had the same problem... i just constinatly beat the hell out of it and the bitch pin finally moved... did you maybe spray it with a lil lube? then give it a few good cracks?
Re: (bh2285)
I used one of the long 10mm bolts that holds the ac condensor to the bracket, I had extra bolts... not sure about you, I had the shifter in neutral the hold time I was banging on it and no luck, then I put it in gear (1st) for some reason it got easier... Good Luck
Re: (kengs)
there is a thread SOME were around here that gives you the exact sized punch to use and how to get it out easily without ****** it up. i have no clue what to search for but its here. maybe check some of the transmision removal threads
TSPeed Factory
Re: (slammed_93_hatch)
use an 8 MM punch. if you use a screwdriver or anything else that's not the correct size it will just simply expand the pin as you pound on it thus making it not want to come out.
Re: (Slammd Sol)
5/16" pin punch or 8mm if you can find one. O, and a nice weighted hammer would help. If you have air tools a pneumatic would make that pin like cake.
we had the same problem. take the linkage out with the motor/tranny and hit it out from the other side. much easier this way.
Re: Taking out the pin that holds the shiftlinkage on...help me please! (peiku)
i hate these fuking pins. i always hit them out with a 12mm bolt. meaning the head is 12mm. the bolt will fit perfectly ontop of the pin and slide right out.
then when reinstalling i just use that 12mm bolt and put a nut on the other side of it. this way i dont have to dick with it again. it works everytime and ive never had a problem with it falling off or breaking
Re: Taking out the pin that holds the shiftlinkage on...help me please! (kyosoeg6)
yeah...but when you use the nut and bolt, doesn't that make your shifter real lose?
i have a nut and bolt on mine right now and my shift is damn lose. i haven't missed a gear, but i would rather have a pin instead of the nut and bolt.
Nation5
14
10-05-2016 02:27 PM
rasinhell
14
02-25-2008 04:01 PM
delsolnewkid
03-11-2006 04:12 PM
