Brake swap help . . .
I own a 2000 Civic ex and will be swapping my rear drums for some Civic Si rear disc brakes. Will my stock ex brakes be sufficient upfront, or should i buy the Si front brakes aswell ? ? Would there be much of a difference upfront ? ?
Thanks
Thanks
Re: Brake swap help . . . (makaveli284)
the front brakes will be fine....in case you are wondering the ex and si both have the same size rotor...but I think the caliper is a little bigger on the si....so all you would need are the calipers.
New User
Re: Brake swap help . . . (PYITR821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYITR821 »</TD></TR><TR><TD CLASS="quote">the front brakes will be fine....in case you are wondering the ex and si both have the same size rotor...but I think the caliper is a little bigger on the si....so all you would need are the calipers.</TD></TR></TABLE>
i have rear disc with a smaller LX front brakes. works like a chimp.
Re: (makaveli284)
I wouldn't say there is a major difference when swapping the rear drums for disks but it does help...after all, all the stopping power is up front.
SHO-NUFF
20
04-12-2007 07:22 AM
Chugger
10-08-2001 09:27 PM
