Sway Bar Question
Sway Bar Question
I went to auto X last weekend. Some guy there told me that if you have sway bar with diameter larger than 17mm you need to reinforce your fram otherwise your sway bar might just tear a chunk off from your fram. Is that true? How is the reinforce thing should be done? I'm putting 18mm in the rear and 20 in the front on 2000 EK hatch.
Thank You
Thank You
Re: Sway Bar Question (Rice Ball)
my oil filter has been fine with my rear sway bar (progress 22mm). my framE has also been ok, i hear having a stiffer suspension helps but its stilll a good idea to make the rear subframE stronger. any one know of any other products than beaks?
1 Post
Re: Sway Bar Question (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">http://www.beaksproducts.com/
reinforcement kit
you only need it in the rear </TD></TR></TABLE>
That what I use - no problems in more than a year.....
reinforcement kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">search is your friend
don't be lazy</TD></TR></TABLE>
I did. Nothing comes up. Maybe I didn't enter the right magic words.
Re: Sway Bar Question (WangChung)
just type in beaks or beaks kit, make sure to check the archives
you will get lots of stuff I'm sure you can find a picture on here somewhere
There is another guy that i have been talkin to about a similar product. I'm not sure if it is available yet or if you would even be interested but here is the link. It is a little more (extreme) race oriented set up, but would be fine on a street car.
https://honda-tech.com/zerothread?id=785497
just watch the topic when he finishes i'm sure he will post something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice Ball »</TD></TR><TR><TD CLASS="quote">I went to auto X last weekend. Some guy there told me that if you have sway bar with diameter larger than 17mm you need to reinforce your fram otherwise your sway bar might just tear a chunk off from your fram. Is that true? How is the reinforce thing should be done? I'm putting 18mm in the rear and 20 in the front on 2000 EK hatch.
Thank You</TD></TR></TABLE>
...........sorry hehe,
p1driftfiend
14
02-23-2004 12:18 PM
