swap vtec wiring
swap vtec wiring
i just dropped in a gsr into ma 92 civic hatch dx everything was successful except that the vtec is not working. if n e one can give me a step by step guide on how to wire the vtec it woul;d be real helpfull thanks .eclps032000@yahoo.com
Re: swap vtec wiring (Justhatched92)
im pretty sure all the 92's were wired for vtec, so it should be plug and play. check the oil level, make sure the car is warm or vtec will not engage, and make sure the vss is working.
Re: swap vtec wiring (white ex)
what wire harness are you using GSR one, or a stock one if it fits (I'm always confused about that). if you are using the stock one you will have to wire it up either to shock tower (since your car is a 92) or straight to the ECU.
Re: swap vtec wiring (ABK)
on the motor the harness is gsr but on the actual car im using stock i heard i have to wire it to the ecu or something if that is da case do u know what sires go were and if u do can u give me some kind of guide on how i can do it
Are you using the gsr ecu? the 92 dx isn't VTEC, so i think you should try to get a gsr harness and ecu, or at least a VTEC harness and a compatable ecu, you can get a p72 on ebay for about $150-200 .... if i am wrong someone say something, dont want you to waste your cash.
Try: http://cgi.ebay.com/ebaymotors...33596
Re: swap vtec wiring (EHwithPotential)
im running the p72 already but is not giving me the vtec something about i have to run 2 wires to the ecu i think from the knock sensor i kno the set up i have is correct the only thing left is to wire the vtec I think.
jumpmann23
04-28-2004 02:10 PM
