converting b18b obd1 into obd2?
how do i do that and what is needed?
i know i have to rewire the dizzy and get obd2 injectors.
i will also need a second o2 sensor.
will i need a cfs? i think...the crank shaft senor thingy by the crank.
anything else?
its a 94 ls going into a 99 cx
thanks and yes i searched that y i got some info already
anything else?
Re: converting b18b obd1 into obd2? (CTRwannaB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRwannaB »</TD></TR><TR><TD CLASS="quote">how do i do that and what is needed?
anything else?
thanks and yes i searched that y i got some info already </TD></TR></TABLE>
you can use obd1 dizzy not a problem, just need to repin
obd2 injectors
CFK sensor(crank fuctuation)
96-99 LS ECU
modify your harness(unless you get EX and decide not to use your stock one)
anything else?
obd2 injectors
96-99 LS ECU
Re: converting b18b obd1 into obd2? (Cnote)
i have an obd2 ls harness if you want to buy it. it has the obd1 injector clips on it so you can still use the obd1 injectors. if not, i can put the obd2 injector clips back on it. let me know...i'll sell it for a good price or will consider trades if you have anything i may want.
