Squeaking for my steering and clutch..... GRRR!!
Everytime I press the clutch in I get a squeaking/creeking noise.
When just sitting stop in neutral or something I can hear a whining from the tranny. I depress the clutch fully and the whining goes away. Throwout bearing???
Finally, I can really notice this while parked, with the car on or off, no matter and turn my wheel either way a loud squeaking noise from my steering somewhere.
Any ideas before I beat something down? lol
Re: Squeaking for my steering and clutch..... GRRR!! (92BlackSi)
My clutch pedal squeaks too. There was a long thread about it in the Type-R forum and apparently it's a common Honda thing. As far as the other two noises I'm not sure but good luck with it.
Re: Squeaking for my steering and clutch..... GRRR!! (hatchdrvr)
my clutch dose the same thing its so gay. its really bad when its raining out or really wet outside and its so embarrising when ur at the light and stuff and you press the clutch down
my clutch does it too....Im used to it
as for the steering, mine was doing that.
For me it was the upper ball joints (they were the old junk/skank2 design)
Replaced, problem solved.
Might as well take a look at them before they take a **** (like the junk2's did.....on a rainy as hell night on a lonely road at 1am)
Re: (pdiggitydogg)
i lube that shaft on the slave cyl i think its called. the one mounted to the tranny that pushes the clutch. the sound goes away but it comes back after awhile. so i kno thats where the sound is but nothing i can do about it
Electrician
The squeak off the clutch pedal is normal. I just replaced my leaking clutch master cylinder and this one squeaks too, but doesn't leak. I'm not sure if you can lube the rod that goes into the cylinder with some grease or not, if anyone has done this without any problem, let us know.
As far as the whine from the clutch itself, might be the throw out bearing.
