DOING A SWAP NEED SOME INFO
i gotta 2000 dx hatch with stock motor right now which im swapping out for b18b(ls) or 99-00 b16
i need a list of everything i need in order to do the full swap for each motor(mounts.wiring harness,etc) im not sure what i need to do the swap and i dont want to buy something and have it be wrong so i figured id do some research b4 buying anything
Re: DOING A SWAP NEED SOME INFO (turtlecx92)
ok that doesnt help me at all being that i know what swap i want i just need to know a full list of things i need for each motor to make it work in my car (mounts, wiring harness, etc)
Re: DOING A SWAP NEED SOME INFO (jay.dee.em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay.dee.em1 »</TD></TR><TR><TD CLASS="quote">ok that doesnt help me at all being that i know what swap i want i just need to know a full list of things i need for each motor to make it work in my car (mounts, wiring harness, etc) </TD></TR></TABLE>
if you read into it more, it should tell you everything you need to know. If your gonna buy a swap, look at http://www.hmotorsonline.com they include EVERYTHING you will need.
sorry all im seeing is bits and pieces of what people think is right.. I need to know for sure so if anyone can make me a list of the stuff i would need for the b18b or the 99-00b16 swap please post it thanks alot..once again the motor is going into a 2000 hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay.dee.em1 »</TD></TR><TR><TD CLASS="quote">sorry all im seeing is bits and pieces of what people think is right.. I need to know for sure so if anyone can make me a list of the stuff i would need for the b18b or the 99-00b16 swap please post it thanks alot..once again the motor is going into a 2000 hatch</TD></TR></TABLE>
You will need....
1.motor and tranny
2.ecu
3.mounts(most likely will come with engine)
4.axles
5.shift linkage
6.new radiator hose
thats all we had to change putting the B18B into my car, if you are going the B16 route, then you will need to wire for vtec and **** like that.
You will need....
1.motor and tranny
2.ecu
4.axles
5.shift linkage
6.new radiator hose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid »</TD></TR><TR><TD CLASS="quote">
What You Will Need
(From the donor car)
1. DOHC power plant
2. Transmission
3. Axles
-DC integras, EG Del sol VTEC, 99+ US Civic Si
4. ECU
- Match your engine, OBDII for less trouble
5. Engine wiring harness
- It is the plugs that you need
6. shift linkages/shifter
- DC integras, EG Del Sol VTEC, 99+ US Civic Si
7. motor/transmission mounts
- you need all mounts except driver side mount (right below the sprockets) where you will use your stock one.
- you will need a 99+ USDM Civic Si rear upper mount.
8. Exhaust manifold
- get a nice light one while you are at it.
9. Catalytic converter
- you will need a larger than stock one if you want to run the JDM 98Spec ITR's 4-1 header.
10. Del Sol VTEC/99+ US Civic Si A/C mounting bracket
- to match your AC compressor make. ie. Nippondenzo (only if you want AC)
11. Helms factory service manuals.
- One for your stock EK and one for your DOHC engine.
Rest is here:
http://hybrid2.honda-perf.org/tech/6gtech.html
What You Will Need
1. DOHC power plant
2. Transmission
3. Axles
4. ECU
8. Exhaust manifold
Rest is here:
If you order from hmotorsonline, also plan on investing in throttle cable being as they cut the ones on their motors, and the D series cable won't work without some level of creativity.
EG-Hatch-CLGS
05-26-2011 09:19 AM
killacam661
10-18-2007 07:20 AM
