OVERHEATING : need some input
this overheating is a mystery to me, i'm trying to help a friend diagnose...
motor:
b18c
aebs sleeved, new headgasket, seals, waterpump, etc (10,000 miles ago)
problem:
the temperature guage shoots up when given throttle, it sometimes shoots up just when sitting in the parking lots and given slight throttle
our "diagnosis":
we have already replaced the following:
-OEM thermostat
-OEM coolant temperature sensor
-OEM coolant temperature sending unit
-OEM fan switch
radiator is full, i'm STUMPED!
help please!
motor:
b18c
problem:
our "diagnosis":
-OEM thermostat
-OEM fan switch
help please!
Re: OVERHEATING : need some input (fakemike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike »</TD></TR><TR><TD CLASS="quote">Are you really overheating or is the needle just jumping around?
I have some input if that is the case</TD></TR></TABLE>
i think you're on the right track...no boiling water or any "smells" of overheating, just an erratic needle
PLEASE let me know whats up
Re: OVERHEATING : need some input (SpoonFedHatch)
When I had this problem it was caused by a poor engine ground connection.
My mechanic saw sparks from the engine ground near the trans., it was pooly grounded. So I cleaned up the connection and every thing was fine.
I have an engine swap and in the process the upper engine ground (on the valve cover) was not reinstalled. So the only ground on the engine was the one on the trans. and it was poorly connected.
So check that your engine is properly grounded.
My guess is that with the engine not grounded properly. Some of the current that should be grounded was messing with the temp gauge on the block.
whoaitzbrain
13
06-30-2012 11:49 AM
alphanumeric
03-04-2006 03:43 PM
SpoonFedHatch
10
11-22-2004 04:23 PM
