Does anyone know how to check codes on a obd 1 conversion ? ( researched )
I helped a friend swap a H22 OBD1 into his OBD2 Civic. Check engine light is on and I can't find info on which pin to ground to read codes from the check engine light flashes. Does anyone know which pin to ground ? Thanks for your help...................
Re: (Jimmy)
https://honda-tech.com/zerothread?id=682412 try this, im currently running odb 1 ecu in a odb2 civic it should be the same, but not 100% sure if it will work for a h-motors...it shouldnt be different
Global Moderator
Re: (JDMFreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=682412 try this, im currently running odb 1 ecu in a odb2 civic it should be the same, but not 100% sure if it will work for a h-motors...it shouldnt be different</TD></TR></TABLE>
I just linked him to that..
jimmy o.
09-25-2008 04:04 AM
