Best Header for a 98 Civic LX Sedan D16Y7?
I recently discovered my manifold was cracked...Giving me reason to buy a header, but i have found that not many companies, that ive seen, make headers for my car... Whats the best and where can i get them?? What are my options???
Re: Best Header for a 98 Civic LX Sedan D16Y7? (Ionix)
id just get a stock d16y8, that will bolt right up and take out your car, i dont think a aftermarket header is going to help you much
Re: Best Header for a 98 Civic LX Sedan D16Y7? (Timmay)
Kamikaze makes a header for your specific application and so does Megan Racing i believe. you'll need a new header n cat combo unless you wanna run cat-less. bu then you'll need to convert to obd1
Re: Best Header for a 98 Civic LX Sedan D16Y7? (reaction360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 »</TD></TR><TR><TD CLASS="quote">Kamikaze makes a header for your specific application and so does Megan Racing i believe. you'll need a new header n cat combo unless you wanna run cat-less. bu then you'll need to convert to obd1</TD></TR></TABLE>
i though you can just throw the cat on after the head and all you need to do is extend the wiring for the O2 sensor? correct me if I'm wrong though.
you can also try here
Re: Best Header for a 98 Civic LX Sedan D16Y7? (Dirk Lance)
i believe the specially made headers are shorter so that you can use a cat. as with the stock dx/cx/lx headers , the cat is actualy apart of the header. I too could be wrong. this may apply to just hatchbacks.
on my y7 i'm running a dc 4-2-1 header for an ex and an ex cat so everything works fine, just extended the o2 sensor wiring as needed.
Re: Best Header for a 98 Civic LX Sedan D16Y7? (sohc_boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy »</TD></TR><TR><TD CLASS="quote">on my y7 i'm running a dc 4-2-1 header for an ex and an ex cat so everything works fine, just extended the o2 sensor wiring as needed.</TD></TR></TABLE>
Same thing I'm running. Works like a charm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy »</TD></TR><TR><TD CLASS="quote">a lil o/t but i was curious ****** u run that 15.8 with the y7 tranny?</TD></TR></TABLE>
No sir, that was with a Y8 tranny. The Y7 is back on though, and the Y8 is in the basement waiting for someone to buy it.
CereaLand
06-08-2003 03:42 PM
