doing a swap soon.. got couple questions to ask..
i am doing a jdm b18c swap into my 92 eh3..
i was wondering if i can use my stock radiator hoses, use my stock o2 sensor?
help me out here.. i am doin the swap on saturday..
hopefully everything goes smooth and be done!!
oh yea!! one more thing..
do i need a B-series throttle cable and bracket?
Modified by 92eh3si at 7:00 PM 9/29/2004
Re: doing a swap soon.. got couple questions to ask.. (Luserkid)
its depends on what model is ur hatch. if its a Cx, u do need to convert to a 4 wires o2 sensor, other then that the dx, si are already 4 wires o2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I think your going to need new hoses, and a 4 (or is it 5) wire 02 sensor. </TD></TR></TABLE>
u will need the new hoses cuz ur old one wont reach to the side of the b18c motor.
Re: (92eh3si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eh3si »</TD></TR><TR><TD CLASS="quote">throttle cable??</TD></TR></TABLE>
anybody??
anybody??
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">u can re-use your stock throttle cable</TD></TR></TABLE>
are u sure? i was told that it would be lil short
TSPeed Factory
Re: doing a swap soon.. got couple questions to ask.. (Mistamike17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistamike17 »</TD></TR><TR><TD CLASS="quote">o2 sensor was only 5 wire/wideband on the vx and hx</TD></TR></TABLE>
you're correct. cx doesn't come with a 5 wire.
Re: doing a swap soon.. got couple questions to ask.. (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">
you're correct. cx doesn't come with a 5 wire.</TD></TR></TABLE>
Yes, it comes with a 1-wire. Hence it also won't work
Throttle cable, you can get it to work by taking a flat peice of steel and drilling holes in it to extent the manifold mounting point, or you can spend the $22 and buy a b-series one (Del Sol VTEC, Integra LS, or ITR)
Edit: Didn't notice it was a GSR manifold *bonk* So those throttle cables would also be wrong. See below
Modified by project_mercy at 12:24 PM 10/1/2004
Re: doing a swap soon.. got couple questions to ask.. (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion »</TD></TR><TR><TD CLASS="quote">btw vx has 4 wire also</TD></TR></TABLE>
Mine didn't. Nor has any other vx I've known that had the OEM D15Z1 in it
Re: (92eh3si)
are u sure? i was told that it would be lil short</TD></TR></TABLE>
no it wont be short. there are a few ways of making it work. i moved the throttle cable bracket to the firwall (took one of the bolts off from the clutch fluid line and mounted the bracket there) and then just put the cable through it and it matched up fine. i will try and get a picture up a little later.
Re: (untitledsn41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitledsn41 »</TD></TR><TR><TD CLASS="quote">
no it wont be short. there are a few ways of making it work. i moved the throttle cable bracket to the firwall (took one of the bolts off from the clutch fluid line and mounted the bracket there) and then just put the cable through it and it matched up fine. i will try and get a picture up a little later. </TD></TR></TABLE>
pics will help!! thanks!!
Re: (92eh3si)
umm, well the pic is kinda low quality but its all i got
the bracket was moved behind the IM, all i did was remove a bolt to the firwall(holding a section of the clutch fluid line up) and place the bracket in its place
Go count em again.
Go count em again.
