water leaks
water leaks
hey all,
I have serious rain leakage leading to water damage. I am growing bitter. So we all know about the window driver & passanger window leaks - they are due to the drying and shrinking of the rubber molding. Now I have a leak under my glove box. Fortunatly it is starting somewhere behind my glove box but they are both driving me up the wall. I go from rainny outside to wet inside.
Any suggestions?
Any suggestions?
Unceasing Measure
The seam between the firewall and the unibody is shitty in our cars and is known to be a huge leak area. You can get to it under the wiper cowl if you'd like to try and fix it by yourself.
Re: (Archidictus)
My Ek was leaking around the tube that runs trhough the firewall right there to drain out your AC. I ran a bead of silicone around the edge of it and no longer have the problem.
pinks11
10-17-2007 02:34 AM
