Stuck on MSD install & I have college in the morning :( PLEASE HELP !!
Old 09-28-2004, 09:25 PM
Snipper Snapper
99SlammedCivic's Avatar
Default Stuck on MSD install & I have college in the morning :( PLEASE HELP !!
Hey guys I"m installing my MSD 6AL on my civic w/ LS motor if that matters..
I have all the wires plugged up correctly , but my cap wont go back on the stupied dizzy....
I already put the rotor peice back on & put the screw in...
why does it not go on ? I"m using the MSD cap btw... it has a Red peice that is hitting the spring ..... ??? I'm stuck.. please HELP... I've been searching, but the only thing I found is the C-speedracing writeup but i need help please !!
Thanks
99SlammedCivic is offline
Old 09-28-2004, 09:42 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Stuck on MSD install & I have college in the morning :( PLEASE HELP !! (99SlammedCivic)
You're using an MSD cap meant for an extermal coil, correct? If you have the stock coil still in there, it probably won't fit. If you don't have an external coil for this setup, you may just be screwed.
Archidictus is offline
Old 09-28-2004, 09:46 PM
Snipper Snapper
hey I do have an external MSD ss blaster coil.. is that right?
so how do I remove the internal one... or can i even do that?
Old 09-28-2004, 09:50 PM
elwood's Avatar
Default Re: (99SlammedCivic)
Should just be two screws holding it in.
Im thinking its the box looking thing
that the spring goes in corect?
I dont know the names for all the parts in the distributor.
elwood is offline
Old 09-28-2004, 09:56 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99SlammedCivic &raquo;</TD></TR><TR><TD CLASS="quote">hey I do have an external MSD ss blaster coil.. is that right?
so how do I remove the internal one... or can i even do that? </TD></TR></TABLE>
Yeah, you need to have an external coil to use the MSD cap, so you've got that part right. Now you'll have to take the rotor off again and remove the internal coil (should be a white, rather large part inside the distributor) so everything fits back together .
You can do it, I have faith in you. Have you run the wires to the external coil yet or are those still attached to the OEM one? If you haven't, it's a shitty night ahead for ya .
Old 09-29-2004, 06:22 AM
Snipper Snapper
Damn it... I hooked everything up correctly I believe but my car wont start
the msd spark plug wires don't fit...... Will my car not start if I'm using the original wires?
Damn this sucks .... any more help?
I'm taking the moms car 2school... rollin luxury 2day but I'd rather my car
Old 09-29-2004, 08:29 AM
Snipper Snapper
Can anyone post up a DIY write up please. ..
thanks !
Old 09-29-2004, 08:42 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99SlammedCivic &raquo;</TD></TR><TR><TD CLASS="quote">Damn it... I hooked everything up correctly I believe but my car wont start
Can you possibly take a picture of how you hooked everything up so we can tell you what you did wrong? A few simple questions:
1.) is the coil connected to the cap?
2.) how many wires are going to the coil from the cap and how many from the battery/MSD box?
3.) what instructions did you follow?
Old 09-29-2004, 08:47 AM
Snipper Snapper
I'll take pics when i get home later on 2day...
I followed the C-SpeedRacing instructions...
http://www.c-speedracing.com/howto/msdbtm/msd.php
^ I have the AL but I figured its similar
A) I have the Big Red wire going to the Pos Batt. Terminal & the Big black to the Neg Batt Terminal
B) I'm using the external SS coil so I have the
orange wire from the MSD to the positive terminal on the coil and the black wire from the MSD to the negative terminal on the coil.
I followed those steps .... Any more info???
I'll take pics when I get home...
Thanks again
Old 09-29-2004, 04:44 PM
Snipper Snapper
Fixed !
Thanks for all the help !
Modified by 99SlammedCivic at 10:18 PM 9/29/2004
Old 10-07-2004, 06:03 PM
92egh22a4's Avatar
glad u got it running. im installing one next week on my car. i hope it turns out cool. what was it that was wrong with yours?
92egh22a4 is offline
Junaid K
03-22-2014 10:26 PM
SpoolnByYou
03-25-2006 09:10 AM
rriicckk787
06-29-2005 06:58 PM
OisinT
01-08-2005 03:35 PM
egizzle8
09-06-2004 04:08 PM
Quick Reply: Stuck on MSD install & I have college in the morning :( PLEASE HELP !!
  • Ask a Question
Question Title:
Description:
