D16Y8 wiring
Please look everyone!
I just bought a y8 and I'm an obd0 ef guy so im a little confused on something. This motor has an electrical plug wiht 3 wires, coming off the motor inbetween the oil pan and block. Can anyone tell me what this is and if its only used by obd2 ecus or does obd1 also use it. Thanks.
Here is a little pic to help u understand.
i used a Z6 harness on my Y7 block (94 hatchback)... and i just didnt plug that harness into anything and my car runs fine
so its just an obd2 sensor you do not need. i guess its the crank position sensor but i dont know doesnt matter anyways
Re: Please look everyone! (=GAMEOVER=)
thanks for the help guys, thats what i wanted to hear. Guess ill just hack it off Thanks for the props on the picture, i worked hard on it
Re: Please look everyone! (hatchback_al)
You SURE he's not talking about the knock sensor on the back of the y8? Its right in that area too...
Sorry, just noticed that its by the crank shaft...my bad.
Re: Please look everyone! (HTechBB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTechBB »</TD></TR><TR><TD CLASS="quote">That plug is actually caled a Crank Position Sensor (very important).
It won't affect your performance but it needs to read info. to send back to your ECU.
Modified by HTechBB at 4:36 AM 9/29/2004</TD></TR></TABLE>
True, but if he's reusing his obd0 distributor and wiring, he wont need to worry about that sensor, because he has one in the distributor.
Re: Please look everyone! (Slopoke)
well I know i use it with obd0, but my main concern is now im swapping to obd1 and Im hoping I wont need to use it. OBD1 doesnt use that plug correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al »</TD></TR><TR><TD CLASS="quote">well I know i use it with obd0, but my main concern is now im swapping to obd1 and Im hoping I wont need to use it. OBD1 doesnt use that plug correct</TD></TR></TABLE>
correct! only obd2 ecu will look for it and throw a CEL if it's not pluged up.
Tru dat see like it says below. (polish)</TD></TR></TABLE>
lol
lol
Hmmmmmm........I don't have mine hooked up on my D16Y8 with OBDI ecu and harness. Also using an OBDII distributor. Everything seems to work fine.
dafuzzbudd
07-02-2008 05:16 PM
SlowSOHC-T
12-13-2007 11:46 AM
