Wiring problem??? Brake light switch, any help would be appreciated.
Old Oct 3, 2005 | 12:33 PM
cbrman's Avatar
Default Wiring problem??? Brake light switch, any help would be appreciated.
Ok so I was installing my alarm system. In order to tap into the parking light wires I took the fuse box/wiring harness down from it's location.
Ever since I did that the rear brake lights stay on if the battery is connected. If I step on the brakes there is no change. To avoid killing my battery I disconnected the terminals.
I think there must be some sort of switch or something when the brake is applied. If so that switch or circuit on my car has some issues.
Anyone know what to look for or does anyone have the wiring schematic for this. It is a 91 crx si.
I got friggen pissed and put my fist through the right rear brake light so I will now need one of those too, but that is after I get this wiring thing fixed..
Thank you.
Steven
Old Oct 3, 2005 | 12:39 PM
MONSTERZC's Avatar
Default Re: Wiring problem??? Brake light switch, any help would be appreciated. (cbrman)
look on the brake padal you should see the brake switch also look for the plug that plugs into it i cant remember the wire colors off the top of my head its a two wire plug if i remember right
Old Oct 3, 2005 | 12:51 PM
b18_crx's Avatar
Default Re: Wiring problem??? Brake light switch, any help would be appreciated. (MONSTERZC)
check the brake light switch maybe it went out......... mine did.........
JakeBP
Mar 6, 2017 04:44 PM
headshrink
Nov 6, 2005 10:03 PM
89dxhunchback
Oct 18, 2005 08:54 PM
4DRPIMPIN
Honda Motorcycles
Jun 8, 2003 08:54 PM
DR. ON POINT
11
Apr 14, 2002 09:34 PM
