wiring help with d16z6 in crx dx
Old Oct 3, 2005 | 08:50 PM
senate33's Avatar
Default wiring help with d16z6 in crx dx
Well basically exactly the same as the title says, i have an 88 crx dx that i am swapping a d16z6 into, i have a p28 ecu and pm6 tell me what the easiest route would be installing it. thanks
Old Oct 4, 2005 | 01:04 AM
NikoZai's Avatar
Default Re: wiring help with d16z6 in crx dx (senate33)
P28 is a must. You'll be using an OBD1 distributor as well.
See http://www.rywire.com for the complete wiring conversion.
You'll be using a Heated 4-wire O2 Sensor.
The conversion is $300 from us, O2 Sensor is $75 if you need it.
Unfortunately, this is the cheapest price on the market, i know it sounds high, but it's worth it.
Give Ryan and I a call, #'s on the site ~ Peter
Old Oct 4, 2005 | 06:57 AM
senate33's Avatar
Default Re: wiring help with d16z6 in crx dx (NikoZai)
sorry man 300 is a little high, i think i will just buy an obd0-obd1 to harness and do the rest of the wiring myself, if anyone has any tips for this please help, i have very limited money supply, thanks for helping maybe i will get some money to buy the conversion but then i still need both wiring harnesses dont i? all i have is the dx harness not the ex and i believe you guys use my harnesses which i dont have so help me out
Old Oct 4, 2005 | 09:10 AM
Rywire's Avatar
Do the dpfi to mpfi, so search that
Old Oct 5, 2005 | 07:05 AM
senate33's Avatar
Default Re: wiring help with d16z6 in crx dx (droppedcrxsi)
any help you guys can give me is appreciated, what about injectors, run the z6 injectors or obd0 with resistor box
Old Oct 5, 2005 | 09:20 AM
Rywire's Avatar
the inj is up to u
Old Oct 5, 2005 | 07:34 PM
senate33's Avatar
i was just wondering what would be easier to do
Old Oct 5, 2005 | 09:24 PM
Rywire's Avatar
leave obd0 is ez er
Old Oct 6, 2005 | 12:13 AM
ALLMOTORCRX20's Avatar
This is what i did
1. pr3 ECU, this will enable vtec to kick in
2.modifity the d16a6 distributor to get timing correctly(cut the inside hole of the top leg)
3.Use stock injectors and oxygen sensor.
4.For the wiring, just wire all 4 injectors, wire cylinder sensor which comes out of the distributor, and change the pins of the crank angle sensor.
Old Oct 8, 2005 | 12:15 AM
NikoZai's Avatar
Default Re: wiring help with d16z6 in crx dx (ALLMOTORCRX20)
I dislike ghetto setups. A non-vtec distributor with a dual cam ECU on a single cam..
That just wrooong I won't get into it.
Did you say you don't have a DX harness?
You don't necessarily need a OBD1 harness, just some plugs from it that you can obtain from almost any decent junkyard.
Distributor plugs, injector run, injector resistor box (if obd0 injectors) Injector block-off plug (if obd1 inj.). O2 sensor plug etc....
We sell ECU jumpers. Give me a call, put a voice to the name, i'll give you a deal where i can.
This is one of the better how-to's for DPFI to MPFI out there.
http://effinmotorworks.com/Effin_MPFI_swap.htm
Old Oct 8, 2005 | 08:02 AM
senate33's Avatar
hey thanks alot yea i do have a dx harness, i actually do plan on getting an ecu jumper im just trying to figure out the rest, if i buy that dont i just have to wire the 4 wire o2 and the vtec and oil pressure for vtec
Old Oct 10, 2005 | 08:21 PM
senate33's Avatar
NikoZai when would be a good time to contact you, im interested in making a deal.
Old Oct 10, 2005 | 09:05 PM
tooann's Avatar
um i'm having the same problem.. i bought a crx with a d16z6 in it and the previous owner had a pr3 ecu in it so now i have a p28 and bought the harness to convert it from obd0 to obd1. If anybody has any detailed walkthroughs it would help a lot
Old Oct 11, 2005 | 08:29 PM
NikoZai's Avatar
Default Re: wiring help with d16z6 in crx dx (tuanxvu)
anytime really, we're very busy, so if you get the voicemail, just leave a message and Ryan or I will get back to you. Calls slow down after 5pm and we are available late.
Yes that's correct about the wires you need to run. 4-wire O2 sensor, VTEC and VTEC oil pressure (with a ring terminal ground wire to the thermostat housing)
Tuanxvu: If you have a P28 and ECU Jumper, you'll need the OBD1 z6 distributor (td-42u), a 4-wire O2 sensor, and a OBD1 VTEC subharness wired to your ECU Jumpers pigtail - Contact Rywire for all.
Honda'sAreDank
Feb 21, 2011 03:21 PM
metalmulisha420
Mar 2, 2006 06:35 AM
madswapper
Mar 28, 2005 07:51 PM
2ndGenREX
May 27, 2003 06:22 PM
