Crx b18a1 swap wiring
Old Oct 7, 2005 | 05:47 AM
TheDelSlo's Avatar
Default Crx b18a1 swap wiring
I need help with the wiring on my 90 crx, i searched a little but kind've unclear, i'm not sure of the model crx (dx,hf, etc.) but it was auto, converted to 5speed. i'm doing a non vtec ls turbo swap. Can someone advise me what harness i should use to wire it up, i have the 93 ls engine harness, can i use that? thanks
Old Oct 7, 2005 | 05:54 AM
CRX Toad's Avatar
Default Re: Crx b18a1 swap wiring (TheDelSlo)
In order to help we really need to know what model you have. In the engine bay back by the firewall is there a black flat round thing on top of the intake?
Old Oct 7, 2005 | 07:22 AM
b18_crx's Avatar
Default Re: Crx b18a1 swap wiring (CRX Toad)
Before we can give you any advice we have to know what model the CRX is. Its either DX, Si, or HF. If its HF or Si you use the si or Hf harness. If its a Dx you have to use a mpfi modified Dx harness and add a couple of wires for injectors.
Old Oct 7, 2005 | 07:50 AM
jspeczcturbo's Avatar
Default Re: Crx b18a1 swap wiring (b18_crx)
he did say it was a auto, hence it can only be a DX, since SI's and HF's were both manual.
Old Oct 7, 2005 | 11:00 AM
TheDelSlo's Avatar
okay so i guess i have a dx, there's no other harness pssiblitles? does hasprt make a harness? can someone give me a nice little right up on the mpfi conversion? =-) thanks
Old Oct 7, 2005 | 11:23 AM
Default Re: (TheDelSlo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheDelSlo &raquo;</TD></TR><TR><TD CLASS="quote">okay so i guess i have a dx, there's no other harness pssiblitles? does hasprt make a harness? can someone give me a nice little right up on the mpfi conversion? =-) thanks</TD></TR></TABLE>here's aobut the best write up taht i found. http://effinmotorworks.com/Effin_MPFI_swap.htm
Old Oct 7, 2005 | 11:51 AM
jlicrx's Avatar
first off, your 93 engine is OBD1 and your car is OBD0 - are you converting the car to OBD1 or converting the engine to OBD0? - makes a difference on what you need to do for wiring - best to convert car to OBD1
Old Oct 7, 2005 | 12:39 PM
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">first off, your 93 engine is OBD1 and your car is OBD0 - are you converting the car to OBD1 or converting the engine to OBD0? - makes a difference on what you need to do for wiring - best to convert car to OBD1</TD></TR></TABLE>eh not really, my car was ofcourse obd0, when we swapped in teh 92 ls motor all we had to do was to use the PR4 ecu and a 90-91 dissy, no extra wiring needs done, but that's if you have a SI, now for his DX since he already has to do a bunch of wiring **** he could convert to obd1 if he choose's, but he doesn't have too.
SIR_APPROVED
10
Nov 30, 2010 07:35 PM
P h i l
Feb 1, 2005 02:52 PM
capbyrd
Dec 16, 2003 03:45 AM
DOHC_EF
Oct 12, 2003 05:56 PM
2ndGenREX
Jun 5, 2003 07:37 AM
