Throttle Vibration? Need advice/pics
Old Oct 4, 2005 | 03:00 PM
Jesterian's Avatar
Default Throttle Vibration? Need advice/pics
Alright, here's my situation. I've got a b16a1 swapped into a 90 civic h/b. I've been troubleshooting the bugs out of it since I got it installed, and suddenly I have yet another one.
When I have the car in gear, and give it more than just a little gas, I get a fairly strong vibration. Nothing that worries me a lot, just enough that I don't like to gas it too hard at all. Now, if I take it out of gear and give it gas, it revs fine. Also, if I get up to a certain speed and drop it into a lower gear, revved fairly high, I get no vibration.
Does this have something to do with my throttle cable, body, etc. ? If so, what can I do, and does anyone have any pics that might be helpful?
Old Oct 4, 2005 | 03:03 PM
Jesterian's Avatar
Default Re: Throttle Vibration? Need advice/pics (Jesterian)
Also, when I start up the car in the morning, the gas pedal often sticks to the point where I have to push it kinda hard to rev the engine, just for that first time. Is this related?
Old Oct 4, 2005 | 03:18 PM
aka's Avatar
aka
I had a vibration when I did mine. My rear mount would vibrate on the rear cross member. The throttle cable sounds like it needs to be replaced.
Old Oct 4, 2005 | 03:19 PM
aka's Avatar
aka
sorry. I had to bend the lip of my rear crossmember down some to get rid of it
Old Oct 4, 2005 | 05:03 PM
virginia_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">Also, when I start up the car in the morning, the gas pedal often sticks to the point where I have to push it kinda hard to rev the engine, just for that first time. Is this related?</TD></TR></TABLE>That sounds line the throttle body is gummed up....a few squirts of throttle body cleaner while working the throttle will clear that up.
Old Oct 4, 2005 | 05:59 PM
Jesterian's Avatar
Default Re: Throttle Vibration? Need advice/pics (virginia_dude)
See, I don't know where that is... Can someone post a pic?
Old Oct 4, 2005 | 06:20 PM
Take off the rubber hose to the air cleaner...this is the ends of the shaft where the butterfly valve is on the end of the intake manifold..a few squirts on either end....flap it open and closed a few times squirt again...4 of 5 cycles adn its clean for 30-40K miles.
Old Oct 5, 2005 | 07:46 AM
Jesterian's Avatar
I need pics. I could stare at that sentence all day long and not understand what that means.
Old Oct 5, 2005 | 11:39 AM
aka's Avatar
aka
take off the intake pipe. Look into the intake manny. do you see that flap that covers that hole? That called the butterfly. You can stick your finger inside the manny and push it open. Do this while the car is off.
Old Oct 5, 2005 | 01:50 PM
Jesterian's Avatar
Default Re: (aka)
I just installed a short ram air intake, could I have done something when I did that?
Old Oct 7, 2005 | 09:41 AM
Jesterian's Avatar
Default Re: (Jesterian)
Alright, I just took off my intake pipe and looked inside the manifold.. All I see is a gold thing covering the inside with a black strip across the middle and a couple of screws in it. Can anyone direct me to a website that'll show me diagrams or pictures of this whole apparatus?
Modified by Jesterian at 11:41 AM 10/7/2005
Old Oct 7, 2005 | 10:47 AM
Jesterian's Avatar
Really want to get this thing running smoothly, nobody has advice?
Old Oct 7, 2005 | 10:59 AM
WRONG AXLES/ OR MID SHAFT WRONG!!!
Old Oct 7, 2005 | 11:24 AM
Jesterian's Avatar
Old Oct 7, 2005 | 11:25 AM
Jesterian's Avatar
Default Re: (BRAAHP!)
These are the axles that shipped with my Hmotors swap.. I don't think they get them wrong all that often.
Old Oct 7, 2005 | 11:26 AM
Jesterian's Avatar
If this helps, it also vibrates a lot when it idles too. In addition, sometimes it vibrates when I throttle and sometimes it doesn't. It comes and goes.
Old Oct 7, 2005 | 11:44 AM
crx_88_si's Avatar
poly hasport mounts being used?
Old Oct 7, 2005 | 02:06 PM
Jesterian's Avatar
Default Re: (crx_88_si)
Yeah, hasport mounts.
Old Oct 8, 2005 | 10:30 AM
Jesterian's Avatar
Bump, still happening. I took it to the local Tires Plus type place and they charged me $20 just to tell me that it was my motor mounts. I don't think they even felt what I was talking about. What a waste of time.
sk8shorty012
76
Sep 29, 2024 11:43 PM
HGZ
May 4, 2013 11:32 AM
F20B_accord
Feb 19, 2011 07:26 AM
dizzzane
Jul 19, 2007 02:50 PM
lilxvtecxpwr
Oct 25, 2002 03:46 PM
