Auto retarding during rev... any ideas why?
Old Oct 3, 2005 | 12:41 PM
T--Rex's Avatar
Default Auto retarding during rev... any ideas why?
B16a turbo obd0 setup, and when i give it gas, even a little it retards the timing... about 1.5 inches... sorry i can't be more precise, but the more gas i give it the more it retards. At idle it is just find though. Any ideas why it is doing this?
Old Oct 3, 2005 | 12:44 PM
Suck my DX's Avatar
Default Re: Auto retarding during rev... any ideas why? (T--Rex)
im not quite sure what u r saying
the cam timing? base timing? what?
what is moving 1.5 inches..u need to articulate in order for us to help you
Old Oct 3, 2005 | 01:35 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Auto retarding during rev... any ideas why? (Suck my DX)
do you have the timing plug jumped? because if you dont, then your ecu is controlling that.
Old Oct 5, 2005 | 08:15 AM
T--Rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">im not quite sure what u r saying
what is moving 1.5 inches..u need to articulate in order for us to help you</TD></TR></TABLE>
yeah, i suppose i should give more details when asking a question like that, when i use a timing light on the underdrive pully, the middle tick doesn't line up at all when i rev the car, it is fine at idle, but like i said as soon as i give it gas it moves up to 1.5 inches away... not sure in degrees, maybe 20 degrees... is that normal? any ideas?
Old Oct 5, 2005 | 07:25 PM
T--Rex's Avatar
i used to be throwing a knock sensor code... not anymore, but could that have somehting to do with it?
Old Oct 5, 2005 | 09:28 PM
sanimalp's Avatar
$cat /dev/urandom
if your car is knocking, then it will go into limp mode. which will most likely retard your timing a lot so you dont blow anything up.
Old Oct 5, 2005 | 11:30 PM
7PSI CRX's Avatar
It's advancing, not retarding the ignition timing.
It's supposed to do that!
Old Oct 6, 2005 | 05:41 AM
drdisco69's Avatar
Default Re: Auto retarding during rev... any ideas why? (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">if your car is knocking, then it will go into limp mode.</TD></TR></TABLE>
Not really though.
Old Oct 6, 2005 | 06:28 AM
BlueShadow's Avatar
Default Re: (7PSI CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">It's advancing, not retarding the ignition timing.
It's supposed to do that!</TD></TR></TABLE>
yup, I looked at the timing numbers in Crome and above 1000 RPMs between 14-26 in/hg timing gets advanced from 16*BTDC to 21.75*BTDC, and at 2000 RPM's it is at 36* BTDC.
So yah that's normal. If it *was* retarding timing at idle and while reving it, you would have a really crappy idle/rev. But I'm sure that's not what's happening.
Old Oct 6, 2005 | 07:06 AM
T--Rex's Avatar
Default Re: (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
So yah that's normal. If it *was* retarding timing at idle and while reving it, you would have a really crappy idle/rev. But I'm sure that's not what's happening.</TD></TR></TABLE>
so it's nothing to worry about... as long as it is good at idle?
Old Oct 6, 2005 | 07:11 AM
BlueShadow's Avatar
Default Re: (T--Rex)
yes
ken2830
Oct 28, 2008 07:24 PM
TravisCadello
Oct 13, 2008 08:08 AM
CIVIC96DXcp
Apr 19, 2005 07:47 PM
EF-21
Feb 20, 2004 09:18 PM
blackANESE
Sep 4, 2002 07:06 PM
