Do the pressure plate bolts use washers?
Old Oct 4, 2005 | 12:34 PM
Jonathan_ED3's Avatar
Default Do the pressure plate bolts use washers?
When I changed the clutch on my h22 EG, I remember the pressure plate bolts used locking washers.
I've got two sets of D series pressure plate bolts and neither set has washers on it.
Do I need to go buy some? Are they supposed to use locking washers?
Old Oct 4, 2005 | 12:38 PM
b18CrxSi91's Avatar
71.179.86.205
Default Re: Do the pressure plate bolts use washers? (Jonathan_ED3)
No, just need to be torqued down to 24ft lbs I believe...I could be off alittle.
Old Oct 4, 2005 | 12:40 PM
But for sure no washers? I've got the TQ specs at work, but it doesn't say anything about the washers.
Old Oct 4, 2005 | 12:45 PM
King-Kong's Avatar
NO WASHERS 100% sure
Old Oct 4, 2005 | 01:32 PM
MONSTERZC's Avatar
Default Re: (turbo_CRX)
2nd their should never be any washers for the pressure plate bolts
Old Oct 4, 2005 | 08:07 PM
Does the situation change if you use an aluminum flywheel?
I had a fidanza flywheel on my h22 with a Clutchmasters stage 3 clutch kit, and it used locking washers on the PP.
Old Oct 4, 2005 | 08:18 PM
fourthgenhatchB17's Avatar
Default Re: (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">Does the situation change if you use an aluminum flywheel?
I had a fidanza flywheel on my h22 with a Clutchmasters stage 3 clutch kit, and it used locking washers on the PP. </TD></TR></TABLE>
When i used an aluminum flywheel on my old sohc zc i did not use any type of washers, i just reused the oem stock bolts.
Old Oct 4, 2005 | 09:35 PM
Well what's strange is that the bolts I used with my Fidanza flywheel actually came with the flywheel.
I guess it doesn't matter. I never had any problems with the h22 or the flywheel/clutch combo.
Just curious, mainly!
Old Oct 5, 2005 | 01:53 PM
31flavorscivic's Avatar
When I did my clutch on my ZC, it didn't use any washers, although it came with all these washers that did not fit the pressure plate bolts, or any other bolt for that matter, so that was a little weird...
Old Oct 5, 2005 | 01:59 PM
SiR Inspired ED7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_CRX &raquo;</TD></TR><TR><TD CLASS="quote">NO WASHERS 100% sure</TD></TR></TABLE>
Old Oct 5, 2005 | 03:49 PM
Crx Jimmy's Avatar
Default Re: (88 Crx Si)
the pressure plate acts as a big lock washer,
vtechjunkie
Jul 23, 2009 10:50 PM
JDM turbo DC
Aug 28, 2007 07:42 PM
DEMNTD1
Jul 27, 2005 03:25 PM
Chillinit
Mar 12, 2005 10:58 AM
