nokia data cable
Old Oct 6, 2005 | 04:28 PM
90crxsi88zc's Avatar
Default nokia data cable
does anyone know the wiring for the nokia cable to laptop for ecu data?
Old Oct 6, 2005 | 04:30 PM
Stefndogg's Avatar
Default Re: nokia data cable (90crxsi88zc)
wrong forum homie
jisu009's Avatar
Default Re: nokia data cable (Stefndogg)
what ECU are you working with?
Old Oct 6, 2005 | 04:33 PM
Default Re: nokia data cable (jisu009)
i have a pm6
Old Oct 6, 2005 | 04:39 PM
jisu009's Avatar
Do you have the ecu apart?
If so, locate an area on the board called the CN2 or CN3. It is 5 little solder dots. That is where you need to solder in a 4 pin header.
The cable needs to transmit RX and TX and also be grounded. The brown wire in your Nokia cable gets soldered to the inner shielding as well as the #1 pin in the CN3 area. The orange goes to the #2 pin on the CN3 and the red wire to #4 on the CN3 area.
http://www.ecucontrol.com/nokiadatcable.htm
Old Oct 6, 2005 | 04:42 PM
jisu009's Avatar
Don't solder the wires directly to the board like he did in those pics in the link...
Use a male and female 4 pin header like this.
Old Oct 6, 2005 | 04:50 PM
thanks alot!.. do you know if i use turboedit if im going to have to keep my laptop in the car and on the whole time?
Old Oct 6, 2005 | 04:59 PM
jisu009's Avatar
no you do not.
Read up on:
http://pgmfi.org/
http://www.turboedit.org/
and buy from http://www.xenocron.com/
Old Oct 6, 2005 | 05:04 PM
InJ3cted's Avatar
https://honda-tech.com/zerothread?id=1171263
scroll down
memorybox
Dec 19, 2006 08:03 AM
JDMlyfestyle
37
Oct 16, 2005 08:42 AM
pinche
Dec 19, 2004 06:21 PM
buckfittyone
Dec 12, 2004 10:16 PM
