Please help!!! ZC swap
Old Oct 5, 2005 | 06:26 PM
EFwithS2000taillights's Avatar
Default Please help!!! ZC swap
Ok here is the deal, I have done a few of these swaps before, but I have never had this problem. Everything is hooked up and all the wiring is secure. The prob is, the motor starts and runs for about 2 seconds and then dies. I checked injector pulse and it only pulses for a second then stops. I replaced my injector box, and it still dies. I have check everything and cant figure it out.
Old Oct 5, 2005 | 06:30 PM
aaronhume's Avatar
Default Re: Please help!!! ZC swap (mouse95338)
could it be a main relay problem? ususally that would just not allow the car to turn on, but if its a bad relay it could keep it from running... just an idea
Old Oct 5, 2005 | 06:33 PM
zccr-xsi's Avatar
is this a dual cam zc?
check your tps wires make sure there correct.
check the main rely.
what cels is it showing?
Old Oct 5, 2005 | 06:38 PM
bcphatchback's Avatar
Default Re: Please help!!! ZC swap (vteckillenzc)
is there a cel? if its the DOHC ZC did you wire up the cam position sensor?
Old Oct 6, 2005 | 09:34 AM
N_A_is_best's Avatar
Default Re: Please help!!! ZC swap (bcphatchback)
last but not least do a compression check to check it the motor is still good
Old Oct 6, 2005 | 10:15 PM
I did a compression check 175 in each hole. It's like my car is on a timer. It runs for a few seconds nice and strong, then it dies. when I spray carb cleaner in the intake it keeps running. But my fuel pressure is fine and my injectors are new. I cant understand
Old Oct 6, 2005 | 10:54 PM
aaronhume's Avatar
Default Re: (mouse95338)
you could try a different main relay just for kicks...
Old Oct 6, 2005 | 11:51 PM
NikoZai's Avatar
That is strange, but what codes are you getting?
Your fuel pressure is definately OK? For sure? because if the "ignition-2" wire is disconnected from the main relay, the main relay will prime your fuel pump (ignition-1 does that) but it wont be on when you start the car.
Probably not it though, thats very rare.
Give it gas? whta happens? still shuts off? MORE INFO
Stop saying it's the main relay Aaron.. it's not the main relay.. maybe wiring to it, but it's not the main relay itself..
Old Oct 7, 2005 | 06:46 AM
Ok I am sure there is fuel pressure, and there are no codes. I have the crx si ecu. I also wanted to let you know that my alternator is not hooked up yet. I remember hearing that on old electronic ignition systems, if the alternator wasn't hooked up it would not run. I have been working on honda's for almost 7 years, and I can't figure this on out. Oh yeah and when I hit the gas pedal it dies faster. When I spray carb cleaner in the intake, it will keep running, until I stop spraying.
Old Oct 7, 2005 | 05:32 PM
bump
Old Oct 7, 2005 | 05:47 PM
bloopie's Avatar
Did you switch the tps wires like your supposed to on a zc?
Old Oct 7, 2005 | 05:51 PM
yes I did. it idles fine, the fuel just cuts off
Old Oct 7, 2005 | 08:46 PM
aaronhume's Avatar
Default Re: (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">That is strange, but what codes are you getting?
that sounds like a good place to check...
Old Oct 7, 2005 | 09:30 PM
bloopie's Avatar
Default Re: (aaronhume)
Have you tried different ecu's?
Old Oct 7, 2005 | 11:40 PM
NikoZai's Avatar
Default Re: (tuner.fish)
Definately try another ECU, i'm at a loss as to what sensor could cause a fuel cut that soon.
Glad you checked to see if it was pulsing. It's electrical/ECU related that's for sure. I'm just trying to figure out if a certain sensor could cause it to cut fuel after running for a few seconds.
Throw a battery charger on that battery, make sure it's not the culprit.
Alternator or no alternator, so long as the battery maintains 12v+ it should run.
A new battery has 400 Amp hours, more than enough to run a car for a few hours.
Does your main relay ever start clicking?
If yes, that means you're getting under 12v+, like 11.8v+ and it can only hold the switch open until the fuel pump primes. Then it loses some of that current, causing the switch to close... then the process repeats.
(Note: Thats not a bad main relay, that's what the main relay should do.)
Old Oct 8, 2005 | 01:17 AM
Lamchop0000's Avatar
try a new/another MAIN RELAY NOW!
Old Oct 8, 2005 | 04:10 AM
Default Re: Please help!!! ZC swap (LamRacing)
^^ im with him, we know what we're talking about. MAIN RELAY!
Old Oct 8, 2005 | 08:46 AM
If my main relay wasn't working, then may fuel pump wouldn't cycle and my computer would not turn on. I can't see why it would be the main relay?
Old Oct 8, 2005 | 09:09 AM
bloopie's Avatar
Have u tried diff. ecu's?
Old Oct 8, 2005 | 10:20 AM
no I have not. I have a 91 integra ecu. will that work?
Old Oct 8, 2005 | 10:34 AM
CBURKE's Avatar
No, i don't think it will. Need an 89 Integra ECU.
Old Oct 8, 2005 | 11:39 AM
bloopie's Avatar
Default Re: (CBURKE)
Thats most likely your problem there buddy.
Old Oct 8, 2005 | 12:30 PM
91whiteZCrex's Avatar
you can use the 91-93 teg ecu on it. i have for alittle bit and it runs fine.
it could be your ecu tho.
make sure its not a automatic ecu tho. we tried one of those once and we got about a mile down the road and it shut off and then wouldnt start
Old Oct 8, 2005 | 01:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mouse95338 &raquo;</TD></TR><TR><TD CLASS="quote">If my main relay wasn't working, then may fuel pump wouldn't cycle and my computer would not turn on. I can't see why it would be the main relay? </TD></TR></TABLE>
the notorious main relay does this.
my sisters 92 integra just recently had this problem.
the car would start up and die after a few seconds. the fuel pump would pump, ECu comes on, but once the car started the car would die. and sometimes when she's lucky it would just start and run. its a vary unconsistant symptom.
i did some research online and everything pointed towards the mainrelay, got a new one at the dealership and stuck it in never had a problem again.
just try it! if that doesn't work at least you can check it off your EASY-TO-FIX list!
Old Oct 8, 2005 | 01:57 PM
Default Re: (LamRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LamRacing &raquo;</TD></TR><TR><TD CLASS="quote">
we had the same problem. do the main reley.
