ZC wiring
Old Oct 6, 2005 | 11:12 PM
CRXsiproject's Avatar
Default ZC wiring
does zc wiring harness different from the crx's or can I use the crx's harness. ( its not a vtec or DOHC, its non-vtech SOHC zc)
Old Oct 6, 2005 | 11:24 PM
aaronhume's Avatar
Default Re: ZC wiring (CRXsiproject)
you can use your crx harness IF its a MPFI injection, which came on SI models or HF models. this is assuming that the zc engine is a 91 or older.
Old Oct 6, 2005 | 11:30 PM
here is the thing, I have the crx with the zc engine and the guy who did the wiring so bad that know my car doesnt even start
Old Oct 6, 2005 | 11:45 PM
NikoZai's Avatar
Default Re: (CRXsiproject)
What model CRX do you have?
The guy should have been using the stock CRX harness. the only difference on an HF/Si is THIS:
http://www.rywire.com/sitozc.shtml
For a DX it gets more complicated.
We can definately repair your stock harness. Let us know how we can help.
Call me tomorrow around 2pm if you can.
Old Oct 7, 2005 | 12:10 AM
Nerologic's Avatar
yeah if u have an hf or si ur set, all u need to do is repind the distro plugs on the harness to connect to the zc distro...
EDIT yous is a SOHC u dont have to do this..
Old Oct 7, 2005 | 09:01 PM
the car use to run but when I played around with the cables it got messed up.( its on DX)
So how would I know that this guy has the right wiring harnes.
Old Oct 7, 2005 | 11:28 PM
NikoZai's Avatar
You MUST use the CRX DX engine harness. You can't plug a Si or HF OR ZC harness into the firewall connectors:
1. it wont plug in to the different size plugs (except for the 14 pin and the 10 pin rectangular)
2. The wire positions won't match on the plugs that DO match (14/10)
3. The wires for the 2 new injectors and distributor aren't on the chassis harness.
SO LOOK at http://www.rywire.com/dxtozc.shtml
This is your best bet of ever getting your car running, no joke.
Nobody "has the right harness".
It's a matter of modifying your existing harness.
You can't just slap one in there. You'll need to add wires to the ECU also.
Old Oct 10, 2005 | 08:38 PM
Default Re: (NikoZai)
but it was working before meaning, when I piked it up it was runing fine then I noticed that the interior lights didnt work so I looked at the fuses and when I did I think I excedently pulled a weak wire witch I dont know were it goes know.
FloMotion
May 29, 2013 08:48 AM
Redemption
Sep 25, 2009 09:48 AM
Dspad_91Civic
May 7, 2004 05:12 PM
SIRX
11
Jan 13, 2003 06:29 AM
vtec_head
May 8, 2002 08:59 AM
