could my Injectors be the problem???!!!!!!!???????
Old Oct 7, 2005 | 08:30 AM
fernruffryders's Avatar
Default could my Injectors be the problem???!!!!!!!???????
well, ever since i could remember, my car has been running wayyyyyyyy tooooo rich. i did a little pretest at a smog shop and my CO was at 10.8, when its supposed to be at 0.7 the guy there said its spraying to much gas. which brings me to next conclusion.
i used v6 injectors i believe, are v6 injectors bigger cc's? or could it be my 02 censor?, if i change injectors, you guys think it will fix it?? thanks in advance.
Old Oct 7, 2005 | 08:41 AM
gnar kill's Avatar
Default Re: could my Injectors be the problem???!!!!!!!??????? (fernruffryders)
v6 injectors? v6 from what?....ummmm that can fry your ecu if you are not careful.....spark could be the problem mine was running way rich when I first got it and it had one plug that wouldn't even fire a corroded rotor and bad cap.....o2 could be problem also...but it would throw a check engine light
Old Oct 7, 2005 | 08:43 AM
Default Re: could my Injectors be the problem???!!!!!!!??????? (gnar kill)
it does throw a cel. well i dont really remmebr off what. i just know it was off a honda i think and there was like 6 injectors or alot of them atleast. so dizzy could be bad?
Old Oct 7, 2005 | 08:56 AM
help me please
Old Oct 7, 2005 | 09:00 AM
crxluv2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fernruffryders &raquo;</TD></TR><TR><TD CLASS="quote">it does throw a cel. well i dont really remmebr off what. i just know it was off a honda i think and there was like 6 injectors or alot of them atleast. so dizzy could be bad?</TD></TR></TABLE>
I'm sure the distributor is fine.
Make sure you are running the correct injectors for your setup then go from there.
Old Oct 7, 2005 | 12:50 PM
d16vtecx's Avatar
Default Re: could my Injectors be the problem???!!!!!!!??????? (crxluv2)
get stock injectors.
cnydc2
May 26, 2005 04:41 PM
Used2beAb16
Apr 11, 2005 08:18 PM
grimald
Nov 26, 2004 04:38 PM
SiRkid
Oct 21, 2003 09:53 AM
