crx turns on then shuts off?
it happen yesterday, i was driving home, pulled over to talk to a buddy.
when i got back in my car and turn it on, it went on fine, but then it died, so i turn it on again and the same thing, on the third time i held the gas (the car wasnt holding its own idle?) for a lil while then the car was able to idle by itself. any ideas? also my radio was shutting off anytime a deep bass note was played( i have subs). i dont know if there related but the both happende the same day?
1989 crx si
313000 miles
i think the dummy at the lube sspot put 5w30 in the motor
1989 crx si
313000 miles
Turn the key to the on position for a few seconds before starting it, and it should get you by till you can figure it out.
Could be the o-rings. Smell the injector rail, and let us know if it smells like fuel.
listen for the clicks from the Main relay. Mine used to do this. I just swapped my relay for a new OEM one (77$!!).
Car would start fine in the morning, then while driving if i shut it off (say to fill up on gas) then go to start it it'll start up and just die right back down. A few cycles of the key later and she fires and stays running.
This also may happen if the car is parked outside on a hot day in the sun.
next time it happens, watch the CEL, it will turn on when you first turn the key, then it will turn off (after 3 sec or so). there should be a little click when it does, if not, the main relay is poop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">Car would start fine in the morning, then while driving if i shut it off (say to fill up on gas) then go to start it it'll start up and just die right back down. A few cycles of the key later and she fires and stays running.
This also may happen if the car is parked outside on a hot day in the sun.</TD></TR></TABLE>
stop for gas...car wont start again....hot day.....hmmm.....sounds very familiar
ahh yes the joys of the MAIN RELAY.... another fun piece on our cars: the IGNITOR
other than that our hondas are pretty hard to disable if they are cared for.
as for the alternator comment, i could see the radio or amp dropping out if it has a low voltage cut out function built into it... but i dont know why the car would die... since the battery should buffer the bad alt enough to keep the ignition going.....? .. unless its bad too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">listen for the clicks from the Main relay. Mine used to do this. I just swapped my relay for a new OEM one (77$!!).
ya I decided it would be better to use an EG one in my car, so i found one at the junkyard and had to re-pin the plug that came with it, and no problems whatsoever since then
oh and by the way it was free instead of $77 for something that might possibly break again
soyou guys think its the main relay? i had pulled it the other day it had a lil rust on the solder. btw if i wiggle the connector by the fuel filter that is filled with dialectric grease the car shuts off and the main relay start clicking like a ****. today it seems to be fine except for low idle under 500 rpms at sometimes.
i just got my alt rebuilt like 2 times. funny thing is when they use the batery checker thingy it says it cant read? but with the probes it reads 14.5?
before u go and buy a main relay. take off ur gas cap and try starting it. you may just have a bad gas cap. i had the EXACT same problem and replaced everything (distributer, relays, fuses) let us no if that fixes the problem
ok i will try that, oh and fyi i have a fudged up eg sittin in my driveway so no spendin here only swappin lol if someone has a diagram let me knwo
if you want to hear the horror as it progress chek out the link
https://honda-tech.com/zerothread?id=1392000
it did it again yesterday i got to rev it to keep it on, after about 40 seconds then it runs normal. but now the tack started going crazy!!!! wtf im getting a main relay today and impicking up a dizzy
it is your battery, not on tight, or a power wire is loose somewhere, happeend to me, sometime car wouldnt start, sometime it would turn off cus my subs also. when car didnt wanan turn on at all, i would open and close my passenger car, and i would have juice. i might be wrong, but for me, that was the problem, battery.
update!! car died on the road to the junkyard, had to pay 75 tow
, opened her up and the damn rotor had backed out
screwed it back in and evrt=ything was good
went home, picked up my girl, went to wendy's
while sitting and eating the dash and radio start getting real dim,
i rev and the lights get bright, then i shut off the car so i could eat.
now the car dont start, and it raining.
got a jump and drove home fine? wtf i got the alt rebuilt like 3 times already in the last month, anyone wanna buuy a crx lol
, screwed it back in and evrt=ything was good
. went home, picked up my girl, went to wendy's
ok now having the same problem with the car dying when i got the lights on with radio, wtf i got the alt rebuilt 2 times in like a month. last month
now napa says the wont take the icm back so im out a total of 175, and still havein issues
Veruka88
15
May 8, 2013 05:26 AM
lukehonda
Aug 4, 2011 03:36 PM
dubzz24
Mar 2, 2007 09:14 AM
