Error 4 code
Old Oct 3, 2005 | 02:45 PM
Conclusive's Avatar
Default Error 4 code
My mechanic is having issues with this. I have a Z6 going into a 1990 DX. It is wired to multi port and uses the resistor box, 88-91 Si intake, and an Integra ECU. (89)
I used an 88-91 Si distributor, and it threw and Error 4 and the engine would not tach over 3500.
My mechanic asked me to order a 92-95 Z6 distributor, so I did. He is getting the same error 4 code and the engine will not tach over 3500. Same exact problem.
What can I do at this point WITHOUT having to convert to OBD-1 and re-wire the entire damn vehicle?
Thanks.
Old Oct 3, 2005 | 02:53 PM
jlicrx's Avatar
Default Re: Error 4 code (Conclusive)
check your distributor wiring - sounds like you have the orange and white wires at ECU pins B10 & B12 switched
Old Oct 3, 2005 | 03:11 PM
Conclusive's Avatar
Default Re: Error 4 code (jlicrx)
He's checking that right now and other wiring.
For a guy who fully built an LSVtec in a CRX and raced very succesfully in H1, this motor sure is being a pain in the keyster.
Old Oct 3, 2005 | 05:46 PM
Conclusive's Avatar
I read on a swap page the 92-95 distributor will NOT work with the Integra ECU.
But then I read on another site that it will work?
Does anybody here have any knowledge with this swap?
Old Oct 3, 2005 | 05:56 PM
Rywire's Avatar
obd1 dizzy WILL NOT work on a obd0 ecu
Old Oct 3, 2005 | 06:14 PM
DTAYLOR's Avatar
New User
Ok, check this out. I F%#k up and installed wire B12 on B14. So I found that and corrected the problem by changing the wires to where they should have gone. But now the car will not start at all. I have checked and double checked and I am clueless now. I guess tomorrow I will try the old diss made for a crx OBD 0.
Any ideas.
Old Oct 3, 2005 | 07:07 PM
jlicrx's Avatar
Default Re: Error 4 code (DTAYLOR)
you need the OBD0 distributor, although it doesn't match up to the Z6 head very well
Old Oct 3, 2005 | 07:17 PM
vw eater's Avatar
i have a obd0 dizzy..
Old Oct 3, 2005 | 07:23 PM
Conclusive's Avatar
Default Re: (vw eater)
I have both. Thanks anyway.
Chad
Old Oct 4, 2005 | 09:13 AM
Conclusive's Avatar
Default Re: Error 4 code (droppedcrxsi)
Thank you jlicrx and droppedcrxsi!
It did turn out to be one of those pins. OBD-0 dizzy is back in and the car is running very well.
I have tons of cash in this car so far.
Bought the d16z6 from the bone yard with 57 k miles.
Stage 1 Clutchmasters clutch.
Fidanza flywheel.
Used an 88-91 Si intake manifold
88-91 resistor box
88-91 Distributor
Stainless header
Paid DTAYLOR for install and MPFI wiring.
Now for the fun stuff.
Car also has:
Four Digital Design 9512's (55 pounds each)
Four of the new Digital Design Z1 amps (5,000 watts each)
Two Hawker 2150 batteries coming
And eight runs of 0 cable.
Old Oct 4, 2005 | 09:28 AM
crx_88_si's Avatar
so why all the performance crap if you have 300+lbs of audio?
Old Oct 4, 2005 | 10:04 AM
Conclusive's Avatar
Default Re: (crx_88_si)
Wouldn't that question be already answered?
Factory DX + 300 lbs
Or D16Z6 + 300 lbs.
Seriously though, the gear only goes in the day before a comp. It stays in my house any other time.
JDMatt3
May 20, 2008 04:51 PM
rustbucketrex
May 27, 2007 08:31 AM
turbob18si
Dec 3, 2006 04:02 PM
extensioncordy
10
Oct 30, 2006 07:21 AM
boostmywankle
Jul 20, 2004 01:09 PM
