need a part # on master cylinder??
well.....its time to overhaul my brake system.....it got to a point that when i come to a stop my brake pedal starts to go all the way to the floor.....so i desided to change everything....i just need to know if anyone has the part # for the ef ex, prelude and accord lxi master cylinder?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">http://www.norcalcrx.org/tyson/brakepartslist.xls</TD></TR></TABLE>
do u happen to know the markings for each one.....i know they have the 15/16 and nissin writen on them....i need to know the marking of each one?
well i installed the ex MC..fit nicelly. i can still use my MC brace too.... put some used rotors that i got from a member in here. bleed the front.....but i thing i messed up my passenger side axel, cause when i bleed the system and was ready to drive it, it made some kind of grinding noice. so i have to go and replace the axel from auto zone. i will be bleeding the whole system again.....cause the pedal still goes all the way down...
i replaced the whole hub, left and right. when i was tring to get the pass side axel from the hub.....i guess i pulled to hard and the axel came off from the spider thing....the + that has the bearing.
adrian sammy
Jun 9, 2019 03:49 AM
