My Ef F**king Hates Me (HELP!!!!!!)
Old Oct 4, 2005 | 08:04 PM
Chico90hb's Avatar
Default My Ef F**king Hates Me (HELP!!!!!!)
After Much dilberation.... I have come to Conclusion the That my Ef Hates me
Problem Number One - Map Sensor (Check Engine Light Blinks 5 Times)
(Changed It 3 Times)
MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
But Everythings Plugged in? mechanical?
Problem Number Two - Rough Idle
Problem Number Three - I Dont Know How to Explan This One But there Goes nothing ... When I Went For a Test Drive I Could only Go 5 mph Then When I tryed To Go Up This Little tiny Hill it Almost Died Because I started to let clutch and Press The Gas it wouldnt go n e more then would roll back down the hill
And What The Hell Does Restricting The Throttle Body?
PLEASE HELP!!!
Old Oct 4, 2005 | 08:07 PM
kulangot's Avatar
Default Re: My Ef F**king Hates Me (Chico90hb)
what car, motor?
Old Oct 4, 2005 | 08:37 PM
Gumbey75's Avatar
Default Re: My Ef F**king Hates Me (kulangot)
check your map sensor and how much air its getting in to the vaccum. and also i think thats the same plug as were ur tps sensor are the same. check if you have them crossed if they are the ones with the same plugs. happened to me b4 good luck
Old Oct 4, 2005 | 08:38 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Check your throttle cable and ground wires... and don't be afraid to take it to a honda dealer.
Old Oct 4, 2005 | 08:39 PM
aaronhume's Avatar
it could be the wires from the map sensor are faulty either in line or possibly at the ecu end... or bad ecu maybe... did you put new vacuum hoses on when you changed the map sensor?
Old Oct 5, 2005 | 07:02 AM
Chico90hb's Avatar
Default Re: My Ef F**king Hates Me (aaronhume)
how do i change faulty wires?
Old Oct 5, 2005 | 07:34 AM
aaronhume's Avatar
well, if they are faulty (as in, when you have both the plug for the sensor and your ecu plugs disconnected) they will either provide no continuity from one end to the other or ground out with the chasis (I think the green wire is grounded though anyway) and if you need to replace them, run 3 new wires and connect them to the plug and to the ecu (you might want to just jew-rig it though unless you want to take the entire engine harness out...)
Old Oct 5, 2005 | 08:26 AM
Take it to a shop. TRUST ME. Wiring is a bitch.
Old Oct 5, 2005 | 09:42 AM
DUFFM4N's Avatar
Default Re: (VashTheStampede)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">Wiring is a bitch.</TD></TR></TABLE>
amen my brother
ef9gonzalez
Oct 11, 2012 06:48 AM
89CivicHb1
Sep 13, 2008 02:44 PM
jordan_civic
May 30, 2008 10:35 PM
D15JDMARIO
Feb 18, 2007 01:52 AM
spooncivic99
12
Feb 19, 2006 06:16 PM
