ZC turbo thoughts
Old Oct 6, 2005 | 08:22 PM
planoguy36's Avatar
Default ZC turbo thoughts
I have a 88 CRX with a ZC swap. I'm planning a turbo system for it. Here's what Ive come up with so far. boost from 6-14 psi on stock internals?
Walbro 255 pump
RC 440 injectors (maybe 550)
Tial BOV and wastegate
Piping and intercooler, Manifold and downpipe.
Hondata ECU (S200?)
Pressure reg.
As far as a turbo I'd like to go with either a T3/T4 BB or a GT30R.
Basically I'm going to run this until it blows the switch to a B16A with rods and pistons. For those of you who have done, this I'd love to hear your thoughts/opinions/ideas.
Old Oct 6, 2005 | 08:39 PM
kulangot's Avatar
Default Re: ZC turbo thoughts (planoguy36)
are you going with obd1?
Old Oct 6, 2005 | 09:13 PM
planoguy36's Avatar
Default Re: ZC turbo thoughts (kulangot)
Good question.. I'm using the integra ECU and have'nt read too much about the hondata unit . (honestly I dont fully understand the difference between OBD0 andOBD1). 'splain please
Old Oct 6, 2005 | 09:28 PM
.Grimace's Avatar
footwork mastery
well if you go with 14psi get that b16 rdy
Old Oct 6, 2005 | 11:18 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: ZC turbo thoughts (BlueSiRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSiRex &raquo;</TD></TR><TR><TD CLASS="quote">well if you go with 14psi get that b16 rdy</TD></TR></TABLE>
Old Oct 7, 2005 | 04:23 AM
virginia_dude's Avatar
Yeah.......its doubtfull you will run very long on stock internals at 14psi....even with good tuning... Stock D series rods aren't up to the task and neither are the cast pistons.
If you want to run that much boost do eagle rods and forged pistons.
Old Oct 7, 2005 | 04:46 AM
SpecialEdxl's Avatar
^word, once you start doing that much boost the stock internals wont handle it and b00m!!!!
Old Oct 7, 2005 | 04:52 AM
Default Re: (SpecialEdxl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpecialEdxl &raquo;</TD></TR><TR><TD CLASS="quote">^word, once you start doing that much boost the stock internals wont handle it and b00m!!!!</TD></TR></TABLE>
I wholeheartedly recomend planoguy36 spends some time on the forced induction forum with the search feature....you will fine anything above 9 psi on sock guts is courting disaster.
Old Oct 7, 2005 | 06:49 AM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by planoguy36 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 88 CRX with a ZC swap. I'm planning a turbo system for it. Here's what Ive come up with so far. boost from 6-14 psi on stock internals?
Walbro 255 pump
Hondata ECU (S200?)
Pressure reg.
</TD></TR></TABLE>fuel pump (good, im still using my stock pump) instead of the rc injectors.... get some dsm blue tops(440cc) they go for $60 tops(set) as far as hondata...dont waste your $$ since your using an integra ecu, use turbo edit(obd-0) it's free software so you just have to get your ecu chipped.
im about to turbo my 2nd car, but my current turbo set up is: dohc zc(in a '91 civic) hf manifold, t-25 turbo, dsm 440 injectors,pr4 ecu with turbo edit, and an eclipse bov and jrc front mount intercooler
Old Oct 7, 2005 | 07:09 AM
EF9ZC's Avatar
ZC turbo baby thats what im talkin bout. I got my **** being built now. Ima put it all together when i get back from iraq. Strokin out my zc. For rods and pistons hit up dh-racing.com he got 800$ combo with rings and everything. ARP studs and headgasket and u be straight. If u need arp part number hollar i got it some where on my favorites
Old Oct 7, 2005 | 09:20 AM
planoguy36's Avatar
Eagle rods
forged pistons
check out forced induction forum
no more then 9psi for now
DSM blue top 440 cc jectors
chipped ECU with turbo edit
t-25 is that ball bearing?
pr4
and dh-racing .com
anything else? I'm writing this all down. thanks 'rexer's
Old Oct 7, 2005 | 09:38 AM
EF9ZC's Avatar
you ever check out zdyne.com they do good ecu conversions fully tunable while running they have been doing it for long time and got good info on site
Old Oct 7, 2005 | 11:26 AM
planoguy36's Avatar
Default Re: (EF9ZC)
Hay Va.dude. Forced Induction Forum.. what a novel idea.. sorry, I didnt see that before I posted. I'll come back when my IQ reaches 100. Thanks.. it lookd like theres a crapload of stuff there for newbies like me. But dont call me stupid yet , I'm just gettin started with this turbo stuff.. BTW, whats "trim" and why does it matter...?
Old Oct 7, 2005 | 01:41 PM
91whiteZCrex's Avatar
if its a dohc zc then its a ok motor to turbo. it can hold around 10lbs of boost no problem. i have know a couple people to do that for a really long time and never had a problem.
he used the old greddy kit with a 15g turbo off a stealth r/t with some dsm 450 and a afc with a dsm sidemount and it pulls pretty hard and it was really simple to do
Old Oct 7, 2005 | 01:42 PM
Default Re: ZC turbo thoughts (virginia_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">
If you want to run that much boost do eagle rods and forged pistons.</TD></TR></TABLE>
the headgasket will go before the rods or pistons.
on a d series anyways. put a better headgasket and some arp head studs and you can push 13 with stock internals.
im speaking from experiance
Old Oct 7, 2005 | 06:36 PM
planoguy36's Avatar
Rockn.. My roomate mentioned something about that..a copper gasket? Have any leads on a "better gasket"? sounds easier then replacing the rods but it is kinda a throw-a-away motor. BUT If i can build it to stand more psi, I'd much rather do that then the hassle of replacing it with a B16. KEEP'm coming, i'm all ears!
Old Oct 7, 2005 | 11:51 PM
99sonicbluegsr's Avatar
i am running 10psi on my dohc zc with stock internals. i have a hks metal headgasket and tunertoyz 450cc injectors. just make sure you get it tuned good and you will not have any problems.
Old Oct 9, 2005 | 11:13 AM
planoguy36's Avatar
Ok after spending the afternoon reading about PR, BSFC, A/R, Lbs/min, compression maps, tirm, exducer, inducer, etc, I've almost come to a conlcusion that at 10psi my best turbo should be a T04E50. Right in the fat part of that "effiecny island" Any confirmations or differing opinions? see I am getting smarter. Thanks for your conintueing tolerence
97grnrs
Nov 10, 2006 07:32 PM
k24ej8
Oct 31, 2006 04:58 PM
MugenFlaredCRX
Jan 13, 2005 09:24 AM
Garrett
Oct 12, 2003 01:05 PM
solely92hatch
15
May 3, 2003 12:06 AM
