vtec is not working
i have a 91 hatch w/ b16 swap the ecu is not letting vtec kick in for some reason can i wire a vtec controller straight to the dist.. and the vtec solinoid and make it work i haVe been throught the whole car couldnt figure it out even sent the car to the shop and everyday they call me with something different like they are tryin to guess and check **** my only problem is i dont ahve vtec will using a controller fix this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrousfedef9 »</TD></TR><TR><TD CLASS="quote">i have a 91 hatch w/ b16 swap the ecu is not letting vtec kick in for some reason can i wire a vtec controller straight to the dist.. and the vtec solinoid and make it work i haVe been throught the whole car couldnt figure it out even sent the car to the shop and everyday they call me with something different like they are tryin to guess and check **** my only problem is i dont ahve vtec will using a controller fix this</TD></TR></TABLE>
Probably same as mine. When I got my car installl, there's NO Vtec kick, therefore, I bought a spoon off ebay and now, Vtec screen loud as hell, louder than my cousin's ITR.
I think you probably need to chip your ecu or buy a chip ecu since it's danger to chip yourself. Well, that's my problem...is the ECU. Ecu makes the different if you got all your wires right where they suppose to be...
is your speedometer working? cuz if not vtec will not kick in.. make sure you wired everything up into the right pins in the ecu. 2nd 02, solenoid, pressure switch, knock sensor
[626] SiRJKwIcK89Ef
Oct 10, 2001 06:37 AM
or it might be the knock sensor... did you leave anything unwired when you finished or is everything wired up? check wiring
