how to clean pistons?
Old Oct 5, 2005 | 12:24 PM
GSRCRXsi's Avatar
Default how to clean pistons?
ok well ive got these pistons and im pretty certain i need to clean them out before putting rings on them and installing them into the block. now my question is, how do i clean them? what can i use to get into the little grooves that the rings sit in?
Old Oct 5, 2005 | 12:38 PM
q45mm's Avatar
Default Re: how to clean pistons? (GSRCRXsi)
Rubbing alcohol and a q-tip
Old Oct 5, 2005 | 12:53 PM
GSRCRXsi's Avatar
Default Re: how to clean pistons? (q45mm)
i dont think a q tip will fit in those grooves, but will rubbing alcohol break up the carbon and all that gunk in there?
Old Oct 5, 2005 | 12:54 PM
1G_DX_to_2G_Si's Avatar
carb cleaner.
or if you have access to it, let them soak in parts cleaner..i believe it's called Safety-Kleen.
Old Oct 5, 2005 | 12:55 PM
EJ1 wilcox's Avatar
Carb cleaner
Go down to your local parts store and pick up a bucket. They come in one gallon buckets with a basket for like $15.
I pulled super super dirty pistons out of an engine I built and soaked them in the carb cleaner for a few hours a piece, the come out looking brand new... no scrubbing or nothing, just let them soak!
I also soaked all the nuts, bolts, and other small pieces I took off that engine, by the time I put it all back together everything was shinning!
IO_303's Avatar
brake parts cleaner has always worked for me
Old Oct 5, 2005 | 01:10 PM
Rywire's Avatar
Default Re: (IO_303)
ya, carb cleaner is what i use
Old Oct 5, 2005 | 01:23 PM
CRX Toad's Avatar
Default Re: (droppedcrxsi)
The steam/pressure cooker that you put blocks in always works well for me. It is nice to have friends with nice equipment.
Old Oct 5, 2005 | 02:15 PM
vegaskurt's Avatar
Default Re: (CRX Toad)
They sell carb cleaner/parts cleaners at most auto parts places. Get one that comes in a bucket and has a basket. Just toss them in and let them soak. The stuff will eat all the crud off the pistons.
Old Oct 5, 2005 | 07:42 PM
GSRCRXsi's Avatar
Default Re: (vegaskurt)
sounds like we got a winner, but one problem. well maybe not a problem, but it could be.
the pistons are still attached to the rods. soaking them in the carb cleaner will eat away the oil and everything on the wrist pins correct? is it possible to spin a wrist pin from lack of oil? or should i just apply some oil after cleaning and work it back into the wrist pin?
Old Oct 6, 2005 | 06:46 AM
EJ1 wilcox's Avatar
Default Re: (GSRCRXsi)
I just throw the whole thing in there... pistons, rods, end caps, everything.
I've cleaned a number of pistons/rods in carb cleaner buckets without ever having any problems.
Just use assembly lube on the bearings during assembly. But you should do that anyways.
sk8board{Pete}
Oct 19, 2008 12:07 PM
GSRCRXsi
Apr 23, 2007 03:30 AM
hondaeg8
Jan 6, 2004 05:08 PM
sshaikh01
May 20, 2003 05:45 PM
