Will DA upper arms work?
I am in need of new upper ball joints and I was told you need to replace the whole upper control arm when you replace it. I need a little camber correction so I was wondering if DA upper control arms would work? I know I can buy some adjustable ball joints from ingalls or something like that but I was told you need a whole new thing so I am very confused. HELP PLEASE SOMEBODY!!!!
I can't confirm that. But why not just go to the local Pick-And-Pull and buy the proper parts? And while you are at it, get a set for a newer (1990-1991) ED/EF Civic/CRX. These newer control arms feature replaceable ball joints, so you won't have to go through this again. Also, ball joint style camber kits will work ONLY on these newer upper control arms.
good info on the topic here: http://www.ef-honda.com/ben/EFhybridsus.php
