ecu questions
ok well i have a crx si and right now i have i/h/e f.p.r, 60 shot. timing advanced about 2 degrees. now my question is DOES A LS ECU HAVE A BETTER FUEL MAP THAN THE CRX SI ECU
and if i put a pr3 ecu in my car will the cel for vtec really slow my car down and if not is that the best ecu to go with. (keep in mind i will be getting eclipse gst injectors and an safc within the next week...
just keep the pr4 if you are getting an safc ecu. The pm6 will be too lean and it is setup for sohc. The pr3 will show cels which are annoying. Still with the pr4.
