Car runs too rich
Old Oct 3, 2005 | 07:38 PM
poundedhatchcrap's Avatar
Default Car runs too rich
whats up everybody, i have a D16a6 motor in my dx hatch and it runs hella rich. Black smoke when i drive hard and it smells like gas sooooo bad in and out of my car. can anyone help me? a few have said i should change my ecu (currently pr4). What do you guys think?
Old Oct 3, 2005 | 07:39 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Car runs too rich (poundedhatchcrap)
yeah probably a good idea since a pr4 is for a 1.8L.
Old Oct 3, 2005 | 07:46 PM
Fobtions's Avatar
Default Re: Car runs too rich (sanimalp)
u guys rememberd to swap the wires on the tps when u went mpfi?
Old Oct 3, 2005 | 07:49 PM
Default Re: Car runs too rich (Fobtions)
wired up all right no problem in that. Just way too much gas. I tried a pm6 but it makes my car really slow. what would you guys recomend for an ecu
Old Oct 3, 2005 | 07:53 PM
Fobtions's Avatar
have u tried swapping it./ u never know.
this happened to a guy i know. cause it really sounds like its at full throttle
Old Oct 3, 2005 | 08:20 PM
tha car runs just fine no tps problems or anything. just too much gas
Old Oct 17, 2005 | 05:25 PM
jdm_ef9_b16's Avatar
try using a pg7 ecu, out of the 89 integra. i had it in my car and loved it.
Old Oct 19, 2005 | 05:24 PM
d15hatch's Avatar
Default Re: Car runs too rich (jdm_ef9_b16)
I have same problem, but different engine.
I think the injector is sticking open for a nano-second too long.
Some seafoam seemed to solve the problem, thoguh.
Old Oct 26, 2005 | 05:16 PM
hey man, check your vaccuum lines. i had the same problem and it stopped after i switched two lines back. try it out, check your map sensor vaccuum and charcoal canister.
Old Oct 27, 2005 | 06:31 AM
Boosted Power's Avatar
Check your injectors, make sure you have the correct injector size. Like someone stated above, try using a PG7 ecu instead of the PR4. The PR4 might be sending out too much fuel for your 1.6L. Remember PR4 is meant for a 1.8L dohc motor.
ls_turbo_#97
Engine Management and Tuning
11
Mar 20, 2009 12:08 AM
cheng_sayaovong
Jan 19, 2009 03:41 PM
90jdmcrxdude
May 5, 2006 10:20 PM
Reason
Nov 7, 2004 08:44 PM
geminis2k
Nov 10, 2003 01:14 PM
