Tires for 15"
Old Oct 6, 2005 | 02:40 PM
Terry36's Avatar
Default Tires for 15"
I have a 89 civic hatch, and i just got 15X6.5 rims, and i was wondering what size tire would you guys recommend? I do plan on lowering my car in the future. I was thinking 195/??/15 but i want to get a second opinion. Thanx..
Old Oct 6, 2005 | 02:43 PM
Suck my DX's Avatar
Default Re: Tires for 15" (Terry36)
195/50/15 is the most common size...
Old Oct 6, 2005 | 02:44 PM
HondaFerris's Avatar
I'd say 195/50R15 is the best overall size for the EF's...Although im rolling on 195/45R15's right now and they work very nicely
Old Oct 6, 2005 | 02:46 PM
Terry36's Avatar
Default Re: Tires for 15" (Suck my DX)
can i go 205? or will that rub? Thanx for the quick response.
Old Oct 6, 2005 | 02:48 PM
205's are a wider tire...It would depend on how low you go...
CRX Toad's Avatar
PSHT 195...get that crap out of here. Suck my DX I am so disappointed you would suggest such a worthless size. Most people around here run a 205/50/15 in fact I will never run anything but that ever again. And they will fit perfect on your rims. We have CRX's that are low and have no rubbing issues with 205's don't be scared. That is also what all EF road course cars run. I am lowered and have NO RUBBING issues.
Old Oct 6, 2005 | 02:50 PM
CRXb18Turbo's Avatar
Default Re: Tires for 15" (CRX Toad)
205/50/15 look good. better traction...
tire hang out a little but it save the rim from curbs,etc...
Old Oct 6, 2005 | 02:53 PM
Suck my DX's Avatar
i run 205/50/15s mounted on a 15X7 wheel...i am dropped 3 in the front 2.5 in the back and i NEVER rub...
i was merely saying that 195/50/15 is the most common size
Old Oct 6, 2005 | 05:13 PM
Chronicsinners's Avatar
with da trailing arms on the back i rubbed with 205-50-15 on slipstreams
As far the best size is concerned 205 is a money size
Old Oct 6, 2005 | 06:16 PM
Crx Jimmy's Avatar
Default Re: Tires for 15" (Chronicsinners)
i dont rub with 225/45/15 on ls 15x6"
Old Oct 6, 2005 | 06:18 PM
kingSfit's Avatar
go with 205 wider = better handling
Old Oct 8, 2005 | 08:36 PM
Terry36's Avatar
Thanx alot guys, i am going to go with 205/50/15. I really appreciate u taking the time to answer my question. Thanx again!!
Old Oct 8, 2005 | 11:15 PM
bagpipe goatee's Avatar
195/50's are the correct diameter for your gearing and speedometer. if you go with the 205, it'll change your gearing a little bit and make your accelleration a little slower, but barely noticible as long as you're not running a d15b2 or something.
Old Oct 9, 2005 | 04:28 AM
SETI20's Avatar
205 is a deathtrap with wet weather. So I'd have to say it depends on where you're from, and what brand tires you run.
Most ppl using the 205's run falkens, wich have a nice hard wall... moth general brand tires SUCK with a soft wall.
Old Oct 26, 2005 | 04:34 PM
Terry36's Avatar
I made up my mind about the size but now i don't know what brand tire i should get. I am looking for good performance tire with good wet traction since i am going to be driving in the snow. Thanx for any input in advance.
Modified by Terry36 at 6:56 PM 10/26/2005
Modified by Terry36 at 7:06 PM 10/26/2005
Old Oct 26, 2005 | 04:40 PM
sadiusomega's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">205 is a deathtrap with wet weather. So I'd have to say it depends on where you're from, and what brand tires you run.
Most ppl using the 205's run falkens, wich have a nice hard wall... moth general brand tires SUCK with a soft wall.</TD></TR></TABLE>
Why are 205's a deathtrap in wet weather?
Old Oct 26, 2005 | 04:45 PM
kingSfit's Avatar
from past results... kumho supra
some i would recommend is
yokohama es100
toyo proxies 4
falken azenis / ziex
Old Oct 26, 2005 | 04:47 PM
EJ2-Fluffy's Avatar
Default Re: (bbun)
Just get some Falken Ziex 512 from JLBmotorsports.
Also get some of these from ROTA! (WORK RSZ-R COPIES)
-Jon
Old Oct 26, 2005 | 04:57 PM
shocker's Avatar
I love my Toyo Proxes-4's on my ls mesh wheels very soft sticky tires that grip well in dry and wet.
Old Oct 26, 2005 | 06:58 PM
RapeV-8's Avatar
205/50/15 will fit as long as the wheels u got are +45 off set!!
Old Oct 26, 2005 | 07:10 PM
hafftrak's Avatar
If you are going to be driving in the snow, I would get a dedicated snow rim/tire set. I plan on running 205/50/15 in the summer and 195/50/15 in the winter. Narrower tires are much better at cutting through the snow, especially on light cars such as ours.
Old Oct 26, 2005 | 07:17 PM
CRX7's Avatar
Get Bridgestone Potenza S03's in 195/50/15 these tires are awesome and usually on sale in this size at tirerack.com for cheap. These are the best rain tire I've ever seen and have loads of grip.
Old Oct 26, 2005 | 07:23 PM
z6's Avatar
z6
Default Re: Tires for 15" (HondaFerris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFerris &raquo;</TD></TR><TR><TD CLASS="quote">205's are a wider tire...It would depend on how low you go...</TD></TR></TABLE>
i have my crx pretty much as low as it will go, and at the track i was running 205/50/15 Hoosier slicks and no rubbing they worked out fine.
Old Oct 26, 2005 | 07:30 PM
SiRex91's Avatar
Default Re: Tires for 15" (z6)
205/50/15 Azenis on a 15x6.5 rim here
And yes there is a big difference between 195 and 205's. When I switched to 205's I noticed a world of difference.
Old Oct 27, 2005 | 04:48 AM
Terry36's Avatar
Default Re: (igotcrx)
i have an offset of +35 Would 205 fit??
I would get 205 if possible, cause i don't plan on driving that fast, mostly city driving.
I drove my 300ZX 5spd throughout the whole winter with summer tire, so i think i can survive in fwd car.
Thanx alot guys for your responses.
