Somethings Draining my battery. NEED HELP!
My battery will drain after about 2 days of not starting it (the battery is fine, its a new optima). Using a multimeter and a test light I have narrowed it down this. If I pull the Stop/Horn fuse under the hood the light turns off and the amp drop off. I took a reading at the horn connections and it did read a small amount of volts, is that normal? Anyone have any ideas on where to go from here?
Originally Posted by Mud666
If you can't fix it with Duct Tape, It's Broken.
Take the horn off and see if it still drain your battery.
More likely the horn relay is no good. Stuck on or touching.
you need to measure current, not voltage to test for current leakages.
hmm... when you charge your battery, check if your brake lights are on. theres a blue plastic/rubber stopper at the brake pedal that often gets broken and will leave the brake lights on constantly, thus draining the battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">hmm... when you charge your battery, check if your brake lights are on. theres a blue plastic/rubber stopper at the brake pedal that often gets broken and will leave the brake lights on constantly, thus draining the battery</TD></TR></TABLE>
This is a common culprit, this is what happened to me a year ago. I dropped some serious cash trying to figure out that it was only a piece of plastic. It is a simple fix once you determine if this is the problem. Don't make the same mistake I did.
teryx000
13
Aug 25, 2009 06:48 AM
