header on a ls/vtec
Old 03-13-2005, 03:08 AM
s2000june's Avatar
Default header on a ls/vtec
can i use a 00 si header on a ls/vtec set up . b18aw/b16 head.
or will it be too short. if so what are all you ls/vtec guys out there using thanks.
Old 03-13-2005, 06:08 AM
Sleek98's Avatar
Default Re: header on a ls/vtec (civicrida3)
im almost certain that it will be to short, you would have to dent up the oil pan to get it to fit. I believe the b18 blocks are 7 cm taller.
Old 03-13-2005, 06:12 AM
Lmgrcivic's Avatar
Default Re: header on a ls/vtec (Sleek98)
yeah the LS block is taller but Ive heard that you can still clear it with the B16 header but you cant use the bracket on the back of the block by the O2 sensor but can anybody confirm this I would just use the LS header though
Old 03-13-2005, 06:36 AM
MassScene's Avatar
it will fit. al b series block have the same casting. therefor they are the same size (on the outside).
Old 03-13-2005, 10:48 AM
95civic LS's Avatar
Default Re: header on a ls/vtec (MassScene)
True I fit an old b16a mainifold on my LS, LSVtec, and B20. Im sure it will fit
Old 03-13-2005, 10:59 AM
Ls_V_TurboSi's Avatar
Default Re: header on a ls/vtec (95civic LS)
I think my cousins using a b16 head on his gsr swap in a civic..
Old 03-13-2005, 11:20 AM
adaml2nv's Avatar
Default Re: header on a ls/vtec (Ls_V_TurboSi)
hmmm on my buddies old car. we had to dent the oil pan alittle to fit a 4-2-1 b16 DC header on his gsr motor.
Old 03-13-2005, 12:13 PM
MassScene's Avatar
Default Re: header on a ls/vtec (adaml2nv)
header could have been bent from bottoming out with out you knowing.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adaml2nv &raquo;</TD></TR><TR><TD CLASS="quote">hmmm on my buddies old car. we had to dent the oil pan alittle to fit a 4-2-1 b16 DC header on his gsr motor. </TD></TR></TABLE>
Old 03-14-2005, 12:45 AM
s2000june's Avatar
thanks guys !!
skiracer8148
03-03-2007 01:18 PM
Vtecme92
09-08-2005 03:44 PM
B16'D DA9
05-29-2005 01:32 PM
93H22A
12-10-2004 07:01 PM
lsvtecivic
05-07-2003 09:07 PM
Quick Reply: header on a ls/vtec
