Strange TPS voltage reading..
Old 03-12-2005, 04:28 PM
93CX's Avatar
Default Strange TPS voltage reading..
Well after much procrastinating I went out and bought a multimeter to test my TPS after everyone told me that was most likely the problem since I've replaced just about everything else that has to do with high throttle bogging and funny idle. So I learned how to use it and hooked it up the red wire and got a reading of 4.5V at idle and .5V at WOT, which is exactly the opposite of what it should have been! I didnt adjust it at all because I was kind of baffled with the results I got. Does anyone have any clue what the issue could be, or if I should unscrew it and start trying to adjust the TPS to .5V at idle and 4.5 at WOT?
TIA
Old 03-12-2005, 05:21 PM
Blind-Fashion's Avatar
Default Re: Strange TPS voltage reading.. (93CX)
sounds like someone had it off and put it on 100% backwards (witch is possible, i did it :-P )
Old 03-12-2005, 06:26 PM
New User
taz77's Avatar
where did you hook up the black lead?
Old 03-12-2005, 10:27 PM
93CX's Avatar
Default Re: Strange TPS voltage reading.. (taz77)
I probed the valve cover to chassis ground with the black.. is that right?
Old 03-13-2005, 07:37 AM
New User
taz77's Avatar
that's the right way to do it.. but i usually go straight back to the battery's (-)
ok, let's try this. hook the black lead to the battery's (-)... use the red lead and check the other wires on the tps.
for the yellow/blue wire, you should be getting close to 5v.
on the green/blue wire (green/black if it's obd2), you should get 0.1v
and i'm assuming you were checking the red/black wire for the tps voltage so forget that one.
Old 03-13-2005, 09:30 AM
93CX's Avatar
Old 03-13-2005, 01:26 PM
93CX's Avatar
Old 03-13-2005, 01:40 PM
jlacoy82's Avatar
Ok, imagine you are looking at the throttle body from the firewall out towards the bumper. Does the Harness plug point up and to the left, or down and to the right?
Old 03-13-2005, 08:27 PM
93CX's Avatar
Default Re: Strange TPS voltage reading.. (jlacoy82)
If I was in the car looking at the motor with X-ray vision it would be down and to the right.. it that right?
Old 03-14-2005, 10:59 AM
93CX's Avatar
Old 03-14-2005, 02:49 PM
93CX's Avatar
anyone out there
Old 03-14-2005, 04:09 PM
hondaracing1's Avatar
bump, got a problem with my TPS also...
Old 03-14-2005, 04:11 PM
jlacoy82's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">If I was in the car looking at the motor with X-ray vision it would be down and to the right.. it that right? </TD></TR></TABLE>
to X-ray. Yes that should be correct.
Old 03-14-2005, 04:16 PM
New User
taz77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">anyone out there</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taz77 &raquo;</TD></TR><TR><TD CLASS="quote">that's the right way to do it.. but i usually go straight back to the battery's (-)
Old 03-14-2005, 05:27 PM
93CX's Avatar
^ why did you post?
Old 03-14-2005, 05:33 PM
New User
taz77's Avatar
i wanted to see what you were getting at the other 2 wires
Old 03-14-2005, 08:13 PM
93CX's Avatar
oh sorry didnt understand. okay i'll probe the other two tomorrow
Old 03-20-2005, 12:03 PM
137's Avatar
I also have a tps problem, its ******* awesome, all of my voltages read back perfect, no electrical problems what so ever... woot ghosts in the machine, so now I;m going to replace my tps just because.
Old 03-20-2005, 01:20 PM
93CX's Avatar
Default Re: Strange TPS voltage reading.. (137)
I probed the other two wires and got correct voltages
Old 03-20-2005, 01:35 PM
Relic1's Avatar
if the 5V and ground wires are reversed the TPS voltage will be reversed like you mentioned.
Old 03-20-2005, 04:28 PM
New User
taz77's Avatar
now... is there ANY reason you can think of on why the voltage might have been reversed? (i.e., you just bought an aftermarket tps, or tb... you just bought the car and this was the first thing that happened when u drove it, someone installed some mods into your car... ANYthing...?)
if u always had the car, and this NEVER happened before, replace the tps
Old 03-21-2005, 07:04 AM
93CX's Avatar
This problem started when I got a new TB because my old one had a sticky throttle plate
Old 04-14-2005, 08:25 AM
RudeLude's Avatar
and i'm assuming you were checking the red/black wire for the tps voltage so forget that one.</TD></TR></TABLE>
i got the same tps problem, are these voltages at idle or wot?
thanks
daniel
Old 04-15-2005, 06:55 PM
RudeLude's Avatar
ttt
Old 04-15-2005, 07:14 PM
93CX's Avatar
Default Re: (RudeLude)
idle should be .5v, WOT should be 4.5v. still havent resolved my problem
93CX
10
02-29-2020 01:40 PM
Kid-jdm-teggy
01-18-2014 07:20 AM
.hawaii
11-13-2009 05:10 PM
One8Hatch
10-23-2001 07:16 PM
Quick Reply: Strange TPS voltage reading..
