coolant leak d14
coolant leak d14
hello everybody
ok... i parked the car today after a hour of non aggressive driving. (no over heating/no smoke/no **** in oil)
i came back to the car an hour later and i saw a coolant puddle under the engine.
i took the car to the shop and did a coolant leakdown test (or however you call it) and it seems that the leak comes from behind the block... what could it be?
best regards moshik galimidi
No Sales Forums
Re: coolant leak d14 (RACEPAK)
If it's coming from behind the block, it may also just be a hose (there are many back there) I would look into that first b4 you start pulling stuff apart. Also does it leak on the side or the rear of the motor/ block? You could also have a water pump problem.
