ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!!
Ok here's what i got for you:
I have a 1997 CX and am swapping a B16A2 from a 2000 SI.
I need wiring help...
Do i use the 2000 si harness? and will it plug right into my CX?
Do i use the 2000 si ECU?
Do i need an obd2b - obd2a jumper harness for this to work correctly?
JUST TELL ME WHAT YOU DID WITH YOUR SWAP PLEASE.
Mr. Badwrench
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (^CX_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^CX_d16 »</TD></TR><TR><TD CLASS="quote">Ok here's what i got for you:
Do i use the 2000 si harness? and will it plug right into my CX? NO use the cx harness
Do i use the 2000 si ECU? you can but you need a 2a to 2b jumper
Do i need an obd2b - obd2a jumper harness for this to work correctly? yes
JUST TELL ME WHAT YOU DID WITH YOUR SWAP PLEASE.</TD></TR></TABLE>
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (boostedcivicsir)
what does that mean?
EDIT: i didnt see the answers lol.... the CX harness isnt gonna work, no VTEC
Location: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Dude I think you have to add the VTEC solenoid wires. Seriously try searching.
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (HalfAnP)
yeah ur gonna need to either add the wires to ur harness or get a 96-98 ex harness, cause i think u also need to add knock sensor wires. the ex harness already has all those wires
No you can't just use the 2000 si harness from what I know...I know you have to modify you harness and change pins around. Also you will need a manual so you can connect your sensors vtec/oil pressure/knock/ect. Are you going the smog legal route of just slap that baby in and run? and expect to run around 14.8's to 15.4's with i/h/e. My friends 98 ek ran 14.5's with a 00 b16a2 with ctr cams i/h/e. But it was blessed...Extremely low mileage b16a2.
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (civic2slo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 »</TD></TR><TR><TD CLASS="quote">yeah ur gonna need to either add the wires to ur harness or get a 96-98 ex harness, cause i think u also need to add knock sensor wires. the ex harness already has all those wires </TD></TR></TABLE>
ya i thought i needed an ex harness, im pretty sure ill go that route, im not gonna run pins from my ecu for vtec, too ghetto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HalfAnP »</TD></TR><TR><TD CLASS="quote">Dude I think you have to add the VTEC solenoid wires. Seriously try searching.</TD></TR></TABLE>
**** you, i'm not just adding a few wires, i wanna do it right and run a ex harness, unless the si one will work, then i am pretty sure i need to extend a couple sensors.
so it'll work if i run an obd2a to b jumper?
I believe you can swap the whole SI harness in, they are both one piece, just different ecu plugs (OBD2B instead of A). Or you could use a 99-00 EX harness.
Mr. Badwrench
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (shifty35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shifty35 »</TD></TR><TR><TD CLASS="quote">I believe you can swap the whole SI harness in, they are both one piece, just different ecu plugs (OBD2B instead of A). Or you could use a 99-00 EX harness.</TD></TR></TABLE>
the interior harnesses are different. it is way too much work to try to make the Si harness work in a 97. use the cx harness, run the wires you need to and you are golden. it is cake.
You're a dick. If you had tried searching you'd see that what I said is the exact same thing most people are saying. Quit bleeding, or would you like a tampon?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
the interior harnesses are different. it is way too much work to try to make the Si harness work in a 97. use the cx harness, run the wires you need to and you are golden. it is cake.</TD></TR></TABLE>
I PUT A B16A2 IN MY BOYS EK 98 CX WE USE HIS STOCK WIRE HARNESS AND RAN A WIRE FROM THE SOLENOID TO THE ECU NOT HARRD
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (REEMB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REEMB18C1 »</TD></TR><TR><TD CLASS="quote">I PUT A B16A2 IN MY BOYS EK 98 CX WE USE HIS STOCK WIRE HARNESS AND RAN A WIRE FROM THE SOLENOID TO THE ECU NOT HARRD</TD></TR></TABLE>
A noobie just schooled you.
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (95excoupe)
lol i don't want to re-pin my ECu, or splice into those wires, damn peaople.
I wanna run a harness tha thas vtec, and most likely run a jumper, i don't wanna hack up my stock harness
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (ReDHaTcHy97)
i know most poeple say to swap the harness with an obd2a, but does anyone know what wires you need to change on the obd2b harness to make it work in a 96 with an obd2b ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^CX_d16 »</TD></TR><TR><TD CLASS="quote">lol i don't want to re-pin my ECu, or splice into those wires, damn peaople.
I wanna run a harness tha thas vtec, and most likely run a jumper, i don't wanna hack up my stock harness</TD></TR></TABLE>
You need to only run three wires!!!
- VTEC Solenoid
- VTEC Oil Pressure Switch
- Knock Sensor
Even if you get an EX harness, you need to add a knock sensor.
- VTEC Solenoid
- Knock Sensor
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You need to only run three wires!!!
- VTEC Solenoid
- Knock Sensor
Even if you get an EX harness, you need to add a knock sensor.</TD></TR></TABLE>
I just picked up an EX harness, already has a knock sensor plug. d16y8 has knock sensors too, i believe. You wan't a clean stock wiring set up.? Pick one up for your hatch. 96-98 EX manual!
You can run the SI ecu but you may need the obd2a-->obd2b conv. harness. OR just get a obd2a CTR or ITR ecu, plugged right up to your EX harness.
btw, my friend has an extra 98 ex vtec manual engine harness. he might sell it.
- VTEC Solenoid
- Knock Sensor
All you have to do is this. You car is a 97 right. use a 96-98 EX M/T wiring harness. It will plug right up plug for plug.. All you gotta then do is run the wires to the ECU and buy yourself a obd-2a to obd-2b conversion harness which is also plug and play. You can get one at http://www.locashracing.com
that way you can use the Si ECU because its obd-2b
Re: (DizzleSizzle)
yup 96-98 EX m/t wire harness, will plug and play perfect
get a obd2a-b harness if you want to use the 99-00 si ecu, or find a p30 and go obd1 with a obd2-1 harness.
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanB6teen »</TD></TR><TR><TD CLASS="quote">When I did my b16 swap in my 97 LX i just dropped it in and i didnt have to do any wiring. I dont know how different the wiring harness is to my LX harness. </TD></TR></TABLE>
and i bet it runs real good
LX have the same harness as dx/cx, which means no vtec and iacv is 3 wire instead of 2, so how did you just drop it in with no wiring?
good luck
Hmmm well first i stopped scamming people. SCAMMER!
Re: ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!! (bboyoracle)
