How does THAT work?
Old 03-12-2005, 01:24 PM
ZedEx's Avatar
Default How does THAT work?
So I took my car to get it inspected...
They said they cant pass it until I get the Passenger CV Boot installed... And yet they made no mention about the MISSING MUFFLER. How is a Split CV Boot a bigger deal than no muffler?
Maybe there is something I'm missing here... Or does this sound just as crazy to you guys?
-Wes
Old 03-12-2005, 01:43 PM
pdiggitydogg's Avatar
Pffff you should be more concerned about a missing cv boot than they are. You have to replace the axle now...because I guarantee that the joint is damaged
Old 03-12-2005, 01:46 PM
SOHC4life 96's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Pffff you should be more concerned about a missing cv boot than they are. You have to replace the axle now...because I guarantee that the joint is damaged</TD></TR></TABLE>
Seriously...... It's not a matter of IF but a matter of WHEN that joint is going to brake. And that is something you don't want to happen.
Old 03-12-2005, 02:55 PM
ZedEx's Avatar
Default Re: (SOHC4life 96)
We have the parts for when that is going to happen... But for now I dont have the time to do it. I have to work around the other crew members schedules... And seeming as the only time we hang out is around mid-night and typically later... That doesnt leave much time to do an axle repair.
But anyways, I'll have it repaired before the next Auto Cross... It just kind of boggles my mind that the muffler was a non existant issue... Kind of odd.
-Wes
Old 03-12-2005, 03:01 PM
RCautoworks's Avatar
Default Re: How does THAT work? (ZedEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZedEx &raquo;</TD></TR><TR><TD CLASS="quote">So I took my car to get it inspected...
-Wes
Why, do they put the car on the dyno over there ? If an axle breaks on the dyno, there could be some serious damage. But what kind of inspection was it ?
Modified by 90blackcrx at 7:35 PM 3/12/2005
Old 03-12-2005, 03:02 PM
SDT Project EF's Avatar
Default Re: (ZedEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZedEx &raquo;</TD></TR><TR><TD CLASS="quote">We have the parts for when that is going to happen... But for now I dont have the time to do it. I have to work around the other crew members schedules... And seeming as the only time we hang out is around mid-night and typically later... That doesnt leave much time to do an axle repair.
-Wes</TD></TR></TABLE>
Well what kind of inspection was this?
teknoracing's Avatar
Default Re: (ZedEx)
Muffler is easy to weld on and costs less. An axle can be a real pain to install. Thats why i always check my boots for tears because i would rather install a boot then have to buy a new axle.
Preventive maintenance is the key
Old 03-12-2005, 04:32 PM
Ls_V_TurboSi's Avatar
Default Re: (teknoracing)
axel is a peice of cake.. It usually takes me about 15-20 minutes MAX to change it.. I dont see what kind of inspection would inspect the axel in the first place...
Old 03-12-2005, 05:11 PM
eg6T's Avatar
Default Re: (Ls_V_TurboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">axel is a peice of cake.. It usually takes me about 15-20 minutes MAX to change it.. I dont see what kind of inspection would inspect the axel in the first place...</TD></TR></TABLE>
u must have access to a lift and a compressor for air tools then to change your AXLE in 20 minutes MAX...
Old 03-12-2005, 05:36 PM
SOHCejcivic's Avatar
Default Re: (eg6T)
^^just switched my driver-side one out tonight in about 20 min. all i have is a jack and hand tools.
Old 03-12-2005, 06:00 PM
Default Re: (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">
u must have access to a lift and a compressor for air tools then to change your AXLE in 20 minutes MAX...</TD></TR></TABLE>
For 20 minutes maybe, but I bet I can do mine in 30 with hand tools
Old 03-12-2005, 06:25 PM
ZedEx's Avatar
It was a regular inspection...
My buddy has changed his quite a bit (they have a Honda or two... Or three... Or four) and he said the longest his has ever taken was 30minutes. With proper tools or course.
I'm not too stressed over it... I'll get to it within the next few weeks or so.
-Wes
Old 03-12-2005, 09:58 PM
Default Re: (ZedEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZedEx &raquo;</TD></TR><TR><TD CLASS="quote">It was a regular inspection.</TD></TR></TABLE>
And what does that mean, was it an emission inspection, bar inspection ??? You have to be a little more specific because it varies on state.
JDMKid05
10-27-2005 07:02 PM
gtowni3
12-24-2004 08:09 AM
Black_Accord
07-14-2003 08:08 AM
BigZ88
12
05-09-2003 03:49 PM
wm5holla
04-18-2003 05:32 PM
Quick Reply: How does THAT work?
