i installed some oem fog lights
i have the wire harness that plugs into the light switch thingey and the oem fog light push button that goes by the defroster button any way i used a guide that i searched and found on h-t worked great i think , every thing was plug and play i cut the hole mounted the fog lights plugged them into the harness pluged the wires in any way followed all the instructions then about an hour and half later i got done with the install looked nice i went to turn them on and i got nothing no foglights so i checked the bulbs and they were blown so i go and buy 2 new bulbs install the bulbs and still nothing so tommorrow im going to recheck all the wires but i dont think thats the problem the fog light button illuminates any advice that i might of done wrong ??? open to all suggestions thanks
Re: i installed some oem fog lights (SPNFEDEJ)
Having a test light will make your life much easier. Buy one if you don't have one (max $10) and check for power at every connection starting with where the bulbs plug in. You may have power, so you'll have to check all the grounds too.
crazi92hb
27
07-14-2005 09:11 AM
