need help badly
Re: need help badly (95civickid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civickid »</TD></TR><TR><TD CLASS="quote">i have no spark hat do i need to do now?</TD></TR></TABLE>
Check battery, alt., and fuses first. Does it turn over?
That's a significantly bland statement. Can you add any description to that? Ex: I tried this and this and this, and it does this and this and this.
sorry i checked all the fuses including in the engine bay under the dash and the alarm fuses none were blown i pulled a spark plug and pluged it into the spark plug wire turned the motor over and no spark. i pulled the cap off and it looks good the rotor spins i dont know what to do now what would be the next step or what needs to be done? pllz help
Re: (95civickid)
you have to bump the starter till it rotates enough to see the head of the screw holding it in. then, just take out screw, then pull off.
Re: (95civickid)
here is my default answer. Check the battery, new cap and rotor, check grounds add some grounds, rinse and repeat. GOod luck i hope you get it fixed
Re: (95civickid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civickid »</TD></TR><TR><TD CLASS="quote">how do i take off the rotor ? i tryed pulling on it but i dont want to break it.?</TD></TR></TABLE>
there is a little screw or allen bolt. very small but it's on the shaft hope that helped.
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Take it to a shop if you don't know what the ignitor is. It looks like a little box with a black tube coming off of it. If I had a pic I would post but I don't, good luck.
mongoliandonuts
23
07-27-2004 02:13 PM
