Help! engine/cluster problems
my tach and my speedo are going all over the place, sometimes when i gas it the motor bogs, however the car idles fine. the motor doesn't rev just up the cluster, unless the rpm isn't at the right spot the motor is running fine. is this a dizzy problem??
b16a2 w/chipped p28 in a eh hatch
Re: Help! engine/cluster problems (PuiPui)
check your engine bay harness. it may of came loose? its located on the t-stat housing its 2 ground wires w/ a 10mm bolt. it would cause all your problems
