tie thingys with motor mounts?
Re: tie thingys with motor mounts? (Redline96LX)
To be more precise my good sir these motor mounts come with zip ties. I was pondering how i might use these with the motor mounts, as say the instruction.
Re: tie thingys with motor mounts? (hotdoggies)
the zip tie "thingies" are what holds the "inserts" in place. read the instructions. they work wonders. after you snug them down, you cut off the excess sticking out. good luck.
i think they just fit around ur motor mounts, like inside the where ur old bushing is, and then u use the zip tie to hold them in... not sure tho... just search motor mount inserts... tons of stuff on them... i was ggonna do this at one point
i did the search and nothing. iam just wonderin how the in the world these things work with the motor mount.
you sure about that??? i just did a search for "motor mount inserts" and returned 184 results... i would try again... make sure that u search the archives
civicsi18
10-27-2008 12:05 PM
