94 HB window problem
I've searched on how to take off the thing that rows the window down on the driver side. My window won't go up all the way and I am in the process of taking off the door panel but I don't wanna risk breaking the thing that rows the window down. How do i take it off?
Re: 94 HB window problem (INVALID)
There is a clip that can be pulled out to take the handle off I think. Let me check. All you should need is a set of needle nose plyers.
EDIT:
Here is a pic. Yeah its a clip.
EDIT:
Re: 94 HB window problem (_BEN_)
if your talking about how to take the door handle crank off, Well there is a horse shoe shape clip holding the hand crank inplace, use a needle nose plyers or like i did use my wifes eye tweezers.....it worked Thanks honey
Location: Why so you can pretend like youre interested, FL/OK
Okay, do this.. get a flathead screwdriver. Pushin the area around where the handle to roll the window up/down is. There is a hardly visible black clip that forms a C-shape around the metal part there. If you push in the area around the handle you should be able to see the little black clip, you will have to use the flathead to push on one of the open ends of that C-shape. The plastic C-shape will probably come shooting out so keep your eyes on it. Once that's off it will allow you to remove the handle so you can finish pulling the door panel from the metal part of the door. Once the bottom of the door panel is all out you should be able to freely pull it towards you, don't pull it all the way out, you're just checking to make sure you got all the clips off. Once you have, just lift up from the bottom, maybe even wiggle it from left to right while you're lifting and it should come right off. Make sure you have removed the little black screw near the upper right hand corner of the (driver side) door, under the back face of the mirrors. Don't worry about breaking the handle or the C- shape clip, if you break a handle I have an extra one that I would give you.
WTF.. it took me that long to type that out-- must be tired.
Modified by INVALID at 3:20 PM 3/12/2005
KillaOJ
03-31-2010 04:41 PM
B18cHatch06
07-18-2007 08:36 PM
