d series mani question?
Re: d series mani question? (utahbmx)
Is that a Y7 motor?
I would try adn find a Y8 manifold to put on it, better manifold
but i couldn't really say what you would ahve to do to put it on, as long as there are all the vacume and coolant ports on it it shouldn't be too bad.
i would think that there shouldn't be any thing like grinding ir anythign you would have to do. I don't think that the Y7 has air injection so you don't have to worry about that. good luck
Re: (POE)
Yeah the y8 manifold is great and is necessary if you want to make any more power out of your y7. All you have to do is put all your y7 manifold parts onto the y8 manifold......... don't forget to change out the y7 throttle body "wheel" with the y8 one, it's pretty important for fitament.
I would also recommend getting an aftermarket header too, it seems they designed the y7 to have as many bad restrictions as possible.
Re: (WildPig)
Thanks for all the help guys, so the sensor(iat) and everthing should just bolt right up to a y8 mani? and I would use the y8 throttle body with the y7 "wheel"?
EG92DX
05-08-2012 12:34 PM
