Anyone with SRR LCA's + Swaybar?
Anyone install a SRR swaybar + LCA's on a EK? I did my install and now it seems like the bolts that go into the subframe/LCA arent long enough anymore to thread through all the way. It just catches a couple threads but its not safe at all. Did I install this wrong or something? Did you guys have the same problem? Help pls.
Re: Anyone with SRR LCA's + Swaybar? (Shaun98si)
I had the same problem man and I just end up using a longer bolts that they had at the shop. I know exactly what you mean, the stock bolts are too short for it.
Actually I had the longer bolts already on my car because I had the SKUNK2 tied bar on it before I put the SRR on. When I put on the SRR I just use that bolts.
Re: Anyone with SRR LCA's + Swaybar? (Greasemonkey)
Thanks for confirming man! Anyone know where I can order some metric bolts? I need Grade 10.9 M10X1.25 90MM or 100MM. Im in canada and I cant find anything locally. I'll gladly order them online. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greasemonkey »</TD></TR><TR><TD CLASS="quote">I had the same problem man and I just end up using a longer bolts that they had at the shop. I know exactly what you mean, the stock bolts are too short for it.
So your saying your using bolts that come with the skunk2 tiebar?
Well I looked @ the skunk site and for sure their tiebar needs longer bolts to be able to install. So I called them up and they are sending me the mounting kit for
10$. Guy says it comes with bolts to replace the stock LCA/Subframe so hopefully god willing this will be the fix.
sjteg
01-10-2004 06:02 PM
