Won't freak'n go into gear. Hard to shift
I have never really worked on transmissions, so I have NO idea what the hell is wrong in my situation - I'm having an extremely hard time going into gear. I literally have to force it into gear and its most difficult when I'm driving. At a stop, it can be difficult at times, but it isn't nearly as bad as when I'm moving. You can hear a grinding noise sometimes or metallic noise when I'm trying to force it into gear.
This is mainly happening when I'm trying to downshift from 5th to 4th, but in general its getting worse and worse.
B18c with a bone stock tranny and stock clutch/disc.
I've checked my hydraulic fluid, and its full.
Thanks,
greg
Thanks,
greg
Re: Won't freak'n go into gear. Hard to shift (Mario.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. »</TD></TR><TR><TD CLASS="quote">Checked your tranny fluid??? </TD></TR></TABLE>
Re: Won't freak'n go into gear. Hard to shift (Daniel san)
it worked fine for the last year, and I didn't beat on this tranny. I was actually easy on this tranny vs. my original D16z.
Re: Won't freak'n go into gear. Hard to shift (importinsider)
does the clutch pedal go all the way down if it doesnt bleed the system and if that doesnt work replace the slave cylander
Re: Won't freak'n go into gear. Hard to shift (melissas_man2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melissas_man2004 »</TD></TR><TR><TD CLASS="quote">does the clutch pedal go all the way down if it doesnt bleed the system and if that doesnt work replace the slave cylander</TD></TR></TABLE>
Yeah I had that problem about a two weeks ago... I had to replace my clutch slave and the clutch master cylinder. It's good to replace both at the same time rather then choosing to only replace one.
