gas tank on 94 civic
i have a 94 civic dx and i think it should have a 12 gallon gas tank or something around there. But i fill my car up just before it gets to E on the meter in the dash. Whenever i fill up my car when the needle is just above E or on E im only pumping in a little less than 8 gallons? is there something wrong w/ the fuel gadge or is my tank only8 gallons which seems realy small to me?
Re: gas tank on 94 civic (Cypher0117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cypher0117 »</TD></TR><TR><TD CLASS="quote">i have a 94 civic dx and i think it should have a 12 gallon gas tank or something around there. But i fill my car up just before it gets to E on the meter in the dash. Whenever i fill up my car when the needle is just above E or on E im only pumping in a little less than 8 gallons? is there something wrong w/ the fuel gadge or is my tank only8 gallons which seems realy small to me?</TD></TR></TABLE>
The fuel tank is actually 11.9 gallons. No serious worries, my car's gauge is the same when it sits above the E mark. When I fill it up I only can put in 9-9.5 gallons. When it actually sits on the E mark or slightly below it then it show be about empty. BTW if you're concern it might be the fuel gauge(which I doubt it) remember it cost $135 from the dealer and is a special order item.
I usually know how much I can go by the miles I've driven and cross check it with my past mileage I put on the car.
Re: gas tank on 94 civic (Lord Helmet)
yeh mine always does that, and each time i try and push it lower and lower, but then at the pump i only pump like 10 gallons which means i still had around 2 gallons to play with...
but i guess the way honda thinks of it....better safe than sorry.
DSBP1
30
01-21-2008 11:05 AM
